Carb to TPI
Car: 1984 5.7L Z28 H.O.
Engine: 4-Bolt 350 5.7L Carb
Transmission: 700R
Carb to TPI
i had a 84 z28 HO with a 305, i swaped a 350 into it and kept the carb, now i want to go to TPI and i was wondering what exactly i need and how much it whould cost?
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Why do you want TPI? The factory form of TPI is far from a performance piece. Its long runner design chokes a 350 by roughly 5000 RPM. If EFI is really what you want, get a Stealth Ram or something like that. The LT1 intake swap is another choice.
If you TRULY want TPI, it would be easiest to find a donor car. You will need sensors, a harness, a new distributor (remote coil, not coil-in-cap), new ECM, just to name a few. The biggest hastle i can see would be the fuel pump.
Car: 88 camaro RS
Engine: that thing under the hood?
Transmission: a what????
i bought my from ebay for 586.00 complete it has everything but the part that covers the dis. and i bought from ebay for 12.00. thats the best place i know of to look.
beachrodder
08-25-2015 08:05 AM
86IROC112
08-17-2015 02:00 PM
Sanjay
08-12-2015 03:41 PM
