choosing correct spark plugs
Car: 1985 camaro
Engine: 1971 355
Transmission: 5-speed
I have a 350 out of a 71 camaro. the heads have been shaved down some due to warpage and I need to get the correct spark plugs for it. I am trying some AC r45ts and it will run but would like to know if they are the correct ones.
George Jeffers
George Jeffers
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
After you run it a bit, look at the electrode. There will be a defined line that "should be" right in the elbow if the plug is the right temperature.
If the line is really close to the spark plug threads, the plug is too hot, go 1 step colder and see what happens.
If the line is past the electrodes elbow and closer to the tip, the plug is too cold, run a hotter plug and see what happens. The line will move when you go up or down in heat ranges.
AC Delco plugs go up in number the hotter the plug
42-cold
43-warm
44-warmer
45 hot
42-cold
43-warm
44-warmer
45 hot
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
AC R-45TS is the stock plug for any chevy peanut plug head for normal driving and low compression.
For "performance driving" with higher compression you can try the plug for a Hi perf Z-28 or Corvette of the era.
AC R-42T or Champion RV8c. It's a non projected tip style that is a little cooler than stock. Works well for me.
1992 Trans Am
05-10-2023 07:19 PM
evilstuie
02-28-2016 03:33 PM
