i have popcorn in my headers
Car: 1983 Camaro Sport Coupe
Engine: 1986 305 C.I.D. Bored .030 over
Transmission: TH350 W/Shift Kit
Axle/Gears: 3:08
hey guys
i have an 83 camaro with a threeofive it has a quadrajet carb on it right now. if i give it too much throttle whether in park of just driving after i let up on it it sounds like popcorn popping under the passanger side. my theory is that the carb is shot and deumping way too much fuel into the headers and its exploding there and since the exhaust runs under the passanger side floor, that made sense to me.
what do you think
1983 CHEVROLET CAMARO with a 1986
305 C.I.D.V8 BORED .030 OVER
HIGH VOLUME OIL PUMP
FLAT-TOP PISTONS
MILD CAM
3" CAT BACK EXHAUST W/ FLOWMASTER MUFFFLER
KEYSTONE CLASSIC WHEELS.
B&M RATCHET SHIFTER
STAGE THREE SHIFT KIT
(she'll spin em into third)
"Wise man once say, friends dont let friends drive Fords!!"
what do you think
FLAT-TOP PISTONS
MILD CAM
B&M RATCHET SHIFTER
i'd say you're right about the fuel getting into the headers and burning there. might be a leaking valve, timing, carb, bad plug/wire, or a few other things. best to check and make sure you have a good tune up first and then start looking for something if it keep up.
ICON Motorsports
1st & 3rd
MM Black Diamond Lodge 538 F&AM
ICON Motorsports
1st & 3rd
Axle/Gears: 3:08
ive jsut done the tune up new wires plugs, etc but i noticed that whne i leave the shifter id drive(instead of shifting it my self) it shifts early, before the max power seems to have been attained.... could this be from bad timeing?
the motor has 22000 miles on it (total rebuild last year)
FLAT-TOP PISTONS
MILD CAM
B&M RATCHET SHIFTER
FLAT-TOP PISTONS
MILD CAM
B&M RATCHET SHIFTER
More likely than unburnt fuel is the catalitic converter. Do you still have one?
Its right under the pass side floor and it can pop when it gets hot more like a tick- tick sound. My guess is the cats plugged up.
Car: 1983 Z28
Transmission: WCT5
I don't have headers but my car made a similar sound, back when it was running . I figured it to be the heat riser valve. It only happened when the engine was idling down and under compression braking. I haven't figured out for sure what caused this but I think the Heat riser valve is the culprit, somehow.
Clem
SCCA TransAm Series Race Mechanic/CrewChief
1983 Z28 with LG4, 5 speed, and (unfortunately) T-tops
1983 Z28, NO T-tops, (unfortunately) Auto Transmission---FOR SALE---
Looking for a V8, preferably 4 or 5 speed Camaro with NO T-tops (wanna trade?)
Clem
Axle/Gears: 3:08
i dont have a cat so thats not it i think that maybe its got something to do with the timin ill check this weekend......
If you're getting an intermittent pop from the exhaust you probably have a header gasket leak. Unburnt fuel gets into the exuaust no matter what you do. It usually passes out the exhaust without popping- UNLESS there is an exhaust leak letting fresh oxygen in somewhere. Then you get popping, expecially on the over-run as the engine is spinning down from high RPMs.
Even without a leak there will be SOME popping and snarling on the over-run. That's how carbureted engines are. FI motors they turn the injectors OFF during an over-run condition so there's no popping in the exhaust. Carbs ain't like that. However, extremely retarded timing will make this situation worse.
redformula88
10-14-2015 06:08 PM
