A/C high side thread type? (adapter)
Car: white 1991 z28 w/b;ack racing stripes
Engine: TPI 350
Transmission: world class t5
I am looking to get some pressure readings on the A/C system in my 1991 z28. I have a dual gauge manifold that has 1/8" npt connections and hoses. They hook up just fine to the low side however they don't fit on the high side. Is there an adapter available so I can leave the schrader valve in and get some pressure readings. Does anyone know what the thread type is (threads per inch or something?) I also have 134 quick couplers that came with my gauges, and I wouldn't mind putting a male quick coupler on the high side, however I would like to leave the system pressureized.
Car: 4
Engine: 6
Transmission: 5
Yes there is an adapter. I have several of them. No I don't know offhand what the thread pitch is; but they're all the same, so if you get a high side adapter, it will have the right threads.
However, my advice would be, if you're that unfamiliar with A/C systems that you don't know about the adapters, don't touch the high side at all. Just leave it alone. Messing with that port isn't necessary for the majority of system service, and you'll probably end up doing more harm than good by dinking with it.
1 Post
Car: 91 RS
Engine: 305 Tbi (L03)
If you want to just read pressures youll be fine tapping into the high side of the system. Just make sure that if you add refrigerant to the high side you have the engine off. Otherwise the compresser will pump refrigerant into your filling container. It will only hold so much before it goes boom.
colton_carlson
03-08-2019 12:21 PM
Linson
08-21-2015 02:12 PM
TA8487
08-16-2015 12:21 PM
db057
08-11-2015 10:11 PM
