msd coil question?
msd coil question?
ok i have a problem with my factory tach and a msd 6al. when i plug the "white" tach wire into the coil "h.e.i." coil in cap dis.(proform 50,000 volt unit). the tach WILL work untill i floor the gas and then it drops to nothing!! i tried plugging the "white" tach wire directly into the msd tach output on the side of the msd box. i read in my msd manual you need to just bypass the rf radio suppresor. but, i cant find it!! i"think" its under the dash? but, i cant find it. i dont need or want to buy the tach adapter. and was wondering if anyone had this problem and how you solved it without buying the 25$ tach adapter??
oh yeah only "SERIOUS" replies....please!! i really need the correct info on this .i have a very high perofrmance street engine and need to fix this prob. A.S.A.P.!!
89 firebird formula
356 10.5:1compression
comp cams xe262 cam
performer rpm intake
#1405 edlebrock 600
sportsman 2 heads 64cc 2.02/1.60 valves 200cc intake runner
msd 6al
h.e.i. proform 50,000 volt vac. advance ditributor
700r-4 with 3.08 first gear and 3.23 posi 7 5/8 rear end.
b trans shift kit(will kill shifts...suck dong!!)
shorty heddman hedders with custom 3" pipe y-pipe back(no damn cat!) with 40 series flowmaster!
future mods: 406 roller REALLY REALLY REALLY RADICAL!!!!!
89 firebird formula
comp cams xe262 cam
#1405 edlebrock 600
msd 6al
anyone??????
89 firebird formula
comp cams xe262 cam
#1405 edlebrock 600
msd 6al
89 firebird formula
comp cams xe262 cam
#1405 edlebrock 600
msd 6al
Don't know if this is going to help much, but it would be great if you or anybody else could find out whats "in" that tach adapter. I'd be interested in assembling one myself(notice the signature). Don't really care to purchase one of the adapters.
Brendan
1987 IROC-Z L98,SuperRam,EB 6085's,LPE 219/219 Roller, Crane 1.6RR, EB TPI Base, 58mm TB, ADS 24#, AFPR, K&N, EB TES, Catco Cat, 3" Borla Cat-Back, Accel cap,rotor,distro/other crap, MSD 6AL, MSD Blaster 3, Aluminum DS, 94 Disk Rear, Adjustable Valve, Precision 3.73 Gears, Sub-Frame Connectors, Hotchkis Lower Control Arms, KYB Shocks/Struts, Suspension Techniques Lowering Springs, Polyurethan Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm,
To see the ROC, Check out the webpage Here
Brendan
same here anyone else?
89 firebird formula
comp cams xe262 cam
#1405 edlebrock 600
msd 6al
89 firebird formula
comp cams xe262 cam
#1405 edlebrock 600
msd 6al
ttt
89 firebird formula
comp cams xe262 cam
#1405 edlebrock 600
msd 6al
89 firebird formula
comp cams xe262 cam
#1405 edlebrock 600
msd 6al
ttft
89 firebird formula
comp cams xe262 cam
#1405 edlebrock 600
msd 6al
89 firebird formula
comp cams xe262 cam
#1405 edlebrock 600
msd 6al
Car: 1987 Trans Am
Axle/Gears: 10 Bolt SLP Torsen, 3.73 ratio
mtx is right, that or the all knowing Vader might know what is in the adapter
Corry Lazarowitz
clazarow@voicenet.com
clazarowitz@hotmail.com
SLP 1 3/4" headers, 3" cat back (stock cat )MSD ignition. MSD Blaster SS coil. More soon when funds are avail...
Corry Lazarowitz
9192camaro
16
02-03-2019 12:21 AM
