Steel braided heater hose?
Car: 1988 GTA
Engine: 5.7L/L98
Can I use any steel braided rubber lined hose (of the correct size of course) for my heater hose connections? Do I need to worry about wether its of special heat resistant rubber or anything, found some a good deal on braided line but they are not sure of its physical qualities.
Car: 83 Z28
Engine: vortec 305 for now
Transmission: 5 speed
Well, to use it correctly the connections need to be of the proper type, unless you just want it to look cool, and use those hose clamp cover things..whatever they are. But that kind of kills the reason for using steel braid.
Car: '82 Z28
Engine: 350HO
Transmission: M4
considering the cost of braided steel hose, and the connections, i don't think it worth it. If your just going for the look, they sell cheap hoes dress up kits that come with sleeves to make rubber hose look like braided steel hose.
Wow. That's like buying a Chrysler Sebring because it's made to LOOK like a Camaro.
Steel braid covered lines? Nylon reinforced lines are much lighter and more efficient. That's why HP tires are nylon belted instead of steel belted.
Car: 1988 GTA
Engine: 5.7L/L98
Well, first off I said I found some good deals, and besides I wasn't asking if you would spend the money on it, I was asking a tech question on the physical characteristics of the rubber in heater hose if there was anything I need to be aware of.
Second theres no "Special" connection on heater hose, the manufactures typically use a spring clamp that rest in front of a tapered nipple on the connection. Pretty much any worm gear hose clamp can do the same job, were not talking high pressure fuel line here.
Third I have given thought (not much mind you) to those cover kits, because yes I am doing this mostly for aesthitic purposes with the extra durability of the steel braid hose as a bonus, and I think those kits look like cheap r1cer alternatives that after time just look worse. If you like them great, you are happy and saved money, cheers to you.
Vader as far as the Nylon wound you are correct and many very reputable car companies (Mercedes, Porsche, BMW) actually use some of that in there stock vehicles. To me the weight savings is pretty much insignificant on a hose, as far as more efficient, Not sure I need more efficiency out of my heater hose, not even sure what that means, Nylon hose allows the fluid to travel faster (no) allows it to stay cooler (maybe, doubtful) last longer than standard rubber hose (definatly), does that make it more efficient!??
Car: 85 Z28
Engine: LG4 modified
They do look like Camaros!
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Car: 1988 GTA
Engine: 5.7L/L98
Originally posted by Apeiron
To realize any benefit out of braided stainless hose, it would need to be used with hose ends and threaded fittings, which the stock rad doesn't have.
Kinda curious also what benifit would you gain by having threaded fittings? You no longer have to use clamps but instead have to thread the connections together? Hows that a benefit. It would handle higer pressures I guess, but this isn't NASCAR I'm dealing with. I have seen those setups on showcars and they do look trick though.
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
Even if you get a "good" deal I cant imagine it being cheap... The size braided line to replace those hoses is EXPENSIVE no matter how good of a deal you get. It may look good but its just not worth it to me. That coolant isn't under any seriously high pressure nor will it cause your car to burn to the ground if the hose cracks and leaks (like a rubber fuel line would).
Stick with some $4 heater hose, theres just no other reason aside from looks to go with braided line
Car: 1988 GTA
Engine: 5.7L/L98
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
I had them on an EFI 400+ FWHP 454HO in an 86 Suburban. They worked fine, but actually seemed to hold the heat in the engine more so than the standard non-braided hoses did. I actually say a 5-10 degree rise in water temps with just these hoses.
Just my $0.02, YMMV.
Have a Great Day!!!
- Vern
Have a Great Day!!!
- Vern
Car: 1988 GTA
Engine: 5.7L/L98
Really Vern, now thats the type of info I am looking for. How did you verify this? Did your car just start running 5-10degrees hotter after you changed nothing but braided lines? I can see how they might hold temp longer within the hose being more insulated, not sure how they could effect temps that much though. Anyone else ever notice this phenomenon?
The temp rise of 5+ degrees was pretty much just observed on the dash guage (a digital unit). No highly technical scientific measurement, but better than the calibrated wrist torque wrench method. In general the underhood temps were always quite warm with that motor, but seemed worse with the all metal shrouded hoses. Just my $0.02
- Vern
- Vern
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
Originally posted by si_camaro
And I thought that was only the opinion of an outsider like myself....
the Sebring came first. the camaros look like Sebrings, not the other way around.
and the LT1 camaros look like geo storms.
*shrug*
Car: 1985 Trans Am
Axle/Gears: 3.70
In my experience the worst part of the braided lines is trying to keep them clean. They look great at first but a couple hundred miles later they start to look crappy, and don't easily clean well. Personally looks wise the std black hoses look the best. IMO
Car: 1988 GTA
Engine: 5.7L/L98
Car: 85 Z28
Originally posted by MrDude_1
no.
*shrug*
no.
*shrug*
Pac J
05-17-2020 10:44 AM
