Cam and vacuum question?
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
1 Post
Car: '85 Camaro
Engine: LG4 305
If you are running a cam that doesn't produce vacuum, what is in place to assist with steering or brakes?
Thanks,
Jason
Thanks,
Jason
1 Post
Car: '85 Camaro
Engine: LG4 305
If that an aftermarket item or OEM? Do they actually work? How? The little bit I understand is that aggresive cams produce NO vacuum. Is that accurate?
Thanks,
Jason
Thanks,
Jason
Car: 87' Iroc
They produce vacuum, just not 20" like a normal motor, maybe 10" or less. However under load they produce vacuum, the reserve can holds the vacuum created from acceleration for use during braking etc.
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Didnt some 4 cylinders like older cavaliers utilize 12v vacuum pumps because the small 4 cyls didnt produce enough vacuum?
What cam are you thinking of that you are concerned about vacuum? Or are you just curious?
1 Post
Car: '85 Camaro
Engine: LG4 305
Just asking in general. From what I understand any cam that generates such little vacuum spits in the face of the CARB and the EPA, so I couldn't use it on the street.
Too bad though. I also here they scream better than any chick in a Dimension Films movie.
Jason
Jason
1 Post
Car: '85 Camaro
Engine: LG4 305
No particular cam in mind
Just general question. I look the cam catalogs, and they refer to minimum vacuum, and I just wondered what happens without the vacuum. Are there cams that have little vacuum that are a wise choice for a car that must pass the sniffer?
Car: No more birdy
If you have a large cam that will not produce vacuum at all there are many different ways to cure that problem. The link RB posted is one, BTW GM uses a hydroboost system on 1 ton+ vans/trucks, a vacuum pump or a can could be used or you could get a manual master. Ive been down around 8in of vacuum on the bird and she still had enough to stop from a roll fairly well (one time).
Location: All over China, Iowa, and San Luis Obispo, CA
1 Post
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: 5.7 TPI, LG4
Transmission: 700R4, 700R4
Axle/Gears: 3.27, 2.73
Also look at what diesel engined vehicles use! No vacuum there ever.
