OK now how Screwed am I ?? take a look>>
Car: 91 z82
Engine: 5.0
Transmission: pro-built 700r4: 2400 stall
http://www.geocities.com/hecubus91/gearpage.htm
this dosn't look good to me
the pic is kinds bad but I'm missing like 4 of the teeth .. do you guys think that I can get away with new gear or what should I do???
Hecubus
Check out my new site http://www.geocities.com/hecubus91
91-Z28 305 Tpi "G92" mods-- K$N/Foil/Cat Back 3" Flowmaster/3" High Flow Cat/B&M shifter/ Intrax Springs/ Kyb Shock's-Struts's/Poly Bushings/Hotchkis Strut Tower Brace/ 100-150 Nos Wet Plate System/ 155lph Fuel Pump/ Holly Adj. Fuel Press. Regulator/Digital Fuel, voltage & Oil Press Guage's/MSD 6al/ Blaster coil/ Optima,Yellow top batt.
"I spent all my money on race cars, beer, and Broads... The Rest I wasted"
Hecubus
Car: 4
Engine: 6
Transmission: 5
Obviously you need a distributor gear... you can get them at aAuto Zone or elsewhere in teh "Help" product line, or you can get one from Comp or Crane through Jeg's or Summit or your local speed shop.
You need to figure out why it did that. Does this car by any chance have a high-volume oil pump? If so, lose it. The oil pump is driven by the dist, so that gear has to stand that load.
ICON Motorsports
ICON Motorsports
lokk at the rest of the teeth, if they are getting thin, then what has happened is that your cam is slowly grinding down on the distributor gear, when if finally gets too thin it will just knock the teeth off. I ordered a cam from summit that did that to my gear twice, turns out they made the cam from the wrong die, so the gears didnt line up right. As for the metal in the pan, most of it has already been filtered through and is fine. I just drained the oil, and got the rest of the pieces out. If the gears were not worn thin, check to see if your oil pump will still turn, if not then that may be your problem. Hope I helped.
Curtis
Curtis
Car: 91 z82
Engine: 5.0
ok Guys sorry it took me so long to get back
but.. ALL of the gears are rasor thin and 4 were either gone or broke off
I checked the cam all the away around and all the gears have a good crest on them... WHEW!
next prob... I can find anyone that sales the gears only.. they all want to hose me for a whole distributor
any body know where I can get one for shure ???
I called Pep boys / Autozone / and more local places..and they won't..
Oh and the Pick up coil was bad as well but I replaced that already and I will check the pump too
anybody ???
THANKS
Hecubus
[This message has been edited by Hecubus (edited April 01, 2001).]
anybody ???
THANKS
Hecubus
Car: 4
Engine: 6
Transmission: 5
I was in the local Car Quest store the other day and noticed them hanging on the shelf in the "Help" section... in Vista, maybe a bit far to go from Bakersfield
ICON Motorsports
ICON Motorsports
hey you can replace the distributor gear but what about the cam? is it ok?? that gear is ****ed!!
89 firebird formula
356 10.5:1compression
comp cams xe262 cam
performer rpm intake
#1405 edlebrock 600
sportsman 2 heads 64cc 2.02/1.60 valves 200cc intake runner
msd 6al
h.e.i. proform 50,000 volt vac. advance ditributor
700r-4 with 3.08 first gear and 3.23 posi 7 5/8 rear end.
b trans shift kit(will kill shifts...suck dong!!)
shorty heddman hedders with custom 3" pipe y-pipe back(no damn cat!) with 40 series flowmaster!
future mods: 406 roller REALLY REALLY REALLY RADICAL!!!!!
89 firebird formula
comp cams xe262 cam
#1405 edlebrock 600
msd 6al
Car: 88 Firebird WS6
I have a gear with less than 500 mi on it. I got a msd so it's not compatable with it. I'll give it up for $5, i'll take care of shipping. If interested e-mail me. If not, you can get the gear from borg-warner for around $30.
'88 Camaro RS 2.8L
'88 Formula 350 (Too many mods to list...)
'88 Camaro RS 2.8L
Car: 1992 Camaro Z28
Engine: 406
Axle/Gears: 4.10 GM 7.5 10-bolt
I had a gear that looked exactly like that. I couldn't figure out why my timing was off, I thought my distributor moved. I was driving back from school one day (90 miles) and when I got off of the expressway, I stomped on it to get the car slideways for my friends. KABOOOM! I thought my motor exploded. Checked under the hood, didn't see anything. Tried starting it again, Kabooom! Sounded like a shotgun blast next to your head. Anyway, I had no oil pressure, when cranking, first clue, and it wouldn't start. I tied up the exhaust that got blown off and had it towed (5 miles, luckily). My ever knowledgable dad says, "sounds like you sheared your distributor gear." Pulled my distributor and low and behold I had a gear that looked like yours. I have a bronze gear to go with my roller cam. I put a cam stop against the timing cover to control "cam walk." It is still wearing, but not as fast. I have a HV oil pump, too. Sorry this is so long. Good luck.
1992 Camaro Z28; Engine:383 w/Ported Edelbrock RPM heads. Lunati Solid Roller Cam 224/232 .502/.502, Fluidampr, Comp Cams 1.5 Roller rockers and lifters, Comp Cams Triple Valvesprings, SVO 30 lb injectors. Holley/Walbro 255 lph in-tank pump, Haltech E6GM DFI, SLP 1 3/4" headers, 4" Mufflex, T56, SLP Clutch, Pro-5.0 Shifter, 4.10 Gear, Auburn Offroad Pro Posi. Super Ram. 17" X 9.5" Ronal FireHawk Rims w/ 275 40ZR17 Bridgestone RE 730's up front and Nitto Drag NT 555R's out back.
Double-Pump This! EFI Rules!
You are not running a roller cam with a standard distributor gear are you?
1992 Pontiac Firebird 350/Six Speed
1987 Toyota Pickup 383/500+ HP
Car: 91 z82
Engine: 5.0
no stock cam stock lifters
but I still can't fina a new gear anywhere
I might have to take you up on that offer If I cant find one
dose anyone know where I can get one???...the only place that I havnt tried is GM but I get off too late to call and check the priceing
any help would be great
thanks
Hecubus
thanks
Hecubus
RedLeader289
05-28-2019 01:47 PM
LT1Formula
10-08-2015 08:34 PM
