Ignition timing tab
Car: Camaro RS Convertible
Transmission: TH700R4
Ignition timing tab
Could we sort this out once and for all.....
I´m still not a 100% sure on how the timingtab should be used ?
I´m attaching this picture of how i think it works.
Could you please help me out here..
Thanks.
Thanks.
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Seems completely backwards. The passenger side should be the driver's side, the front of the car should be the rear of the car, the slot marked "+8" should be zero, and each mark going up should be 2 degrees (Before Top Dead Center).
If you could get another picture that shows the marks and numbers to the right, that should clear it up.
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
That was what i thought. What is the timing tab mounted to? But as five7 says, and i agree, in most that i have seen, there are an equal amount, if not more, marks indicating BTDC than ATDC.
I was standing on the passengerside taking the photo.
And the timingtab is mounted on the timingchaincover.
Car: '99 HO Z28 / '03 Trailblazer
Originally posted by Rhydon
Posting a better picture (the old one was a bit confusing).
Engine: LS1/LQ4
phess has it right - "+" being BTDC, "-" being ATDC.
The "tabs" and "valleys" are not equally spaced. Each tick mark is two degrees, so the tabs are not of equal value.
Ghettobird52
07-05-2024 11:18 PM
