tat tat tat tat tat tat......
Car: 89 camaro RS and 90 camaro IROC Z
Engine: 2.8MPFI V-6 and 350TPI 5.7 liter V
car wont start and it makes a tattat noise when cranking... its not the battery so is my starter bad????
Car: 1989 C4
Axle/Gears: 307
Check battery voltage, battery connections all (4). If these check out you could have a bad soleniod. Of course a replacment solenoid costs nearly as much as a cheap starter.
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Your battery voltage is low, check it with a multimeter, when cranking and when not cranking. Below 12 volts is not good. And indicates the battery is bad or not fully charged.
Wishmaster's87IROC
09-18-2007 08:49 AM
