Here's the difference in gas tanks that I found...comments?
<a href="http://pcola.gulf.net/~jza/89RS%20-%20fuel%20tank%20swap%20-%2089%20fuel%20tank%20-%20left%20side.jpg">Out of 89RS</a> - had fuel starvation problems around 1/4 on turns, even worse with less (delicate turns)..
<a href="http://pcola.gulf.net/~jza/89RS%20-%20fuel%20tank%20swap%20-%2092%20fuel%20tank%20-%20left%20side.jpg">Out of 92RS</a> - never had problems.
This was after my fuel pump died. I went ahead and stuck in a better tank while I was at it. I like the results.
The argument was that some better tanks were baffled better than others and some had a plastic sump where others did not. But both of these are baffled the same inside, the difference that you can see in the pictures is the height and design of the plastic piece inside. I wish I could look at a 1LE tank to compare notes..
Anyone have the knowledge?
[This message has been edited by Jza (edited March 26, 2001).]
Your links dont work...
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
13.25 @ 107.18 MPH
Southern California
I used part #10269091 to get my baffled tank.
1989 IROC-Z 5.7L
NOS 150HP kit
ProBuilt 700R4, PI Vigilante 2800 stall lockup
Baer Brakes 12" Sport System
1989 IROC-Z 5.7L
NOS 150HP kit
The later years of 3rd gen production they used some (all?) of the baffling technology derived from the 1-LE racing tank in the run-of-the-mill gas tank. I remember reading about the problem of fuel starvation with the in-tank electric pumps below 1/4 tank of gas which the 1-LE tank fixed. Later models of the 3rd gen, even the base models, got upgraded fuel tanks with baffles.
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
That tank is $240 + shipping
from http://www.gmpartsdirect.com
Zepher
'86 Pontiac Trans Am WS6, LG4 305, 5 Speed, CF DF Clutch,
Edelbrock 1406 Carb, Edelbrock Performer RPM 7101 Intake Manifold.
Edelbrock Open Element Air Cleaner: Flowmaster Exhaust, 160* Thermostat,
Grant GT Steering Wheel, MSD HEI Coil, Taylor 8mm Wires, Leather 96 Camaro SS Seats,
Alpine CD+Changer,Alpine V12 Amps, Premier TS-1040C Subs, Polk Audio highs/mids.
Best ET: 14.94@91.67
High Speed Run: 157mph
WS6 Trans Am
Zepher
WS6 Trans Am
Car: 86 Iroc-Z28
Engine: FB385
Hey JZA, ever get to check out a 1LE tank to compare? The reason i ask is b/c if i can get this "1LE" tank for cheap, not $240+ new, then i will swap it too when i do my fuel pump. Even if it just turns out to be a 89-up tank, its still better than my 86, right? I'll have to ask the guy more questions about the tank before i buy it but i want to double check here first. While doing a search i came across a few part numbers. 1LE tank:12509285, baffled tank:10269091, sending unit:25027221, special strainer?:25027354. Now, when you did your swap, you used all of your stock stuff, like the sending unit, right? It should all fit together, i can't see why they would go out of their way like that for this type of stuff, but maybe they did! All i am looking to buy is this "1LE" tank and a new fuel pump. I should be fine with this, correct? My car has 81k miles on it and i have had no other problems with the tank or fuel system. Just upgrading the pump for security and i would be upgrading to this new tank b/c its cheap, "new", better, and convenient right now. Let me know what you think, thanks for your time.
AkDrifted
08-17-2015 07:45 PM
