What size screws in fuel pressure regulator
1 Post
Car: 1988 GTA
Engine: 5.7L/L98
I lost a screw to my fuel pressure regulator, anyone know what size it is. My thread checker doesn't go small enough. Its jsut about the same dia. of a #6-32 but thread is wrong an M4 is to big. Maybe an M3?? Anyone know for sure??
Car: trans-am
Engine: tpi
AHAHaha, I feel better knowing im not the only one with this problem. I just found out that they are a 1/2 size metric too. Did you find anywhere thad had the bolts? I visited several hardware stores and found nothing. I need to replace all of mine. Some ding-dong striped out the top where the star bit goes in. I had to use locking pliers to unscrew the bolts. What store did you find your at?
1 Post
Car: 1988 GTA
Engine: 5.7L/L98
Well I cheated, one of my threads got cross threaded and the bolt snapped. So I was going to chase the threads with a tap and go find the right size bolt. We did not have a 3.5M tap so I tapped it out to 4M and the 4M x 12mm screw was easy to find. If you cannot find the screw at your regular hardware or auto stores I don't know what to tell you I guess you could go straight to GM. Good luck.
Car: 1985 IROC-Z28
Engine: TPI 350
Transmission: TH700-R4
Hmmm, sounds funny,
I could get this kind of screw everywhere ... ah, I see ... you donīt live in Germany
Uwe
Uwe
Car: trans-am
Engine: tpi
Was fur ein dumkopf bin ich. Ich mochte zu Berlin flugen! Ich spreche ein bischen Deutche. Anyway, if you feel generous you could smuggle some of them through customs and bring them to me, it would save me a trip there.
Bitte ein Bit!!! MMMM, Lecker!
9192camaro
16
02-03-2019 12:21 AM
