Will Perf. RPM fit under the stock hood?
I just got my car back from an engine swap (305 to 350, yeah baby!). Originally I got a Performer RPM Intake manifold, but between it and the carb adapter, I couldn't get the hood to close with an air cleaner on it, not even a drop base. I am planning to get a new carb and intake as well as a distributor to rip the computer out of my car. I was wondering if the RPM topped with a perf. carb and drop base filter will fit under the stock hood? It was so close that I think it might. Anyone running a similar setup with a stock hood?
DG
1984 Z28 LG4/A4
Mods: are you kidding? They cost money.
Powered by Eclipse, Kicker, Rockford Fosgate, JL Audio, and MB Quart.
DG
1984 Z28 LG4/A4
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I doubt it. I had a low profile intake and a Holley on my small block. A 2" tall air cleaner was all that could fit under the hood. The Performer RPM intake is tall. Reguardless of what carb you happen to use, you will not have enough room. You're going to have to install a cowl or hood scoop if you want it all to fit.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z Pro ET Bracket Race Car
383 stroker (carbed) with double hump cast iron heads and pump gas
461 Big Block installed and ready for the 2001 racing season
Best results before the 383 blew up
Best ET on a time slip: 11.857 altitude corrected to 11.163
Best MPH on a time slip: 117.87 altitude corrected to 126.10
Altitude corrected rear wheel HP based on power to weight ratio: 476.5
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Best 60 foot: 1.662
I use a Moroso drop base with K&N 14X3 filter and it fits fine.
91 RS/3.1 - Stock except stereo system, daily driver.
86 IROC - Pep Boys 350 longblock, Performer 750 carb, Performer RPM intake, Comp Cams 280 magnum, Hooker 1 5/8" shorties, Flowmaster Y pipe, 3" pipe to Flowmaster 2 chamber Dual outlet, TH 350 performance rebuild w/shift kit, Daco 2600 Stall, 3.42 Gear Moser 12 bolt w/Eaton posi.
I'am running a preformer RPM manifold with a 600 Carter comp. carb.on my 84-Z28 with the stock hood and a drop base air cleaner and it is tight but works just fine. It is also a 350
Car: 94 Z28
Engine: LT1 w/ headers, catback, CAI, tune
Axle/Gears: 3.23s
Yeah it will fit. I have a 14x3 inch filter setup w/ a 1 1/2 inch drop base on top of my holley 750. Fits under the stock Z hood just barely. Not sure how well it flows air w/ the inside top of the lid so close to the choke tower. I just recently got a K&N Xtream lid that I think helps that...
Ray87Z
-Vortec headed 350.
86 IROC w/ a cammed 305 TPI.
Formerly Ray86IROC.
www.inter-scape.com/Ray
Ray87Z
-Vortec headed 350.
Formerly Ray86IROC.
I ended up going with the cowl hood on my 84 to keep the performer rpm. I've heard of some people being able to use a drop base, but it wouldn't fit on mine.
1984 Z28 350
Never argue with an idiot, they'll just bring you down to their level and beat you with experience
My Web Page
1984 Z28 350
My Web Page
I'm running a performer RPM with a Holley 600cfm carb and the LG4 single snorkel air cleaner. It barely fits under my hood. I can't measure it, but my guess is that the stud for the air cleaner wing nut isn't more than 1/8" below the hood.
82 Camaro:
350, Erson cam, ported heads, Crane Hi-6 ignition, Accel supercoil, Comp Cams 1.6:1 rocker arms, Turbo 350 tranny with 2500 stall.
82 Camaro:
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
My friend has a 350 with a Perfomer RPM intake and 600 Edelbrock carb and it fits fine under his stock hood with his drop base cleaner!! He even has a spacer too because he was too cheap to buy the banjo fitting for the fuel line...LOL!!
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Fits on my car, but it is a very tight fit.
Zepher
'86 Pontiac Trans Am WS6, LG4 305, 5 Speed, CF DF Clutch,
Edelbrock 1406 Carb, Edelbrock Performer RPM 7101 Intake Manifold.
Edelbrock Open Element Air Cleaner: Flowmaster Exhaust, 160* Thermostat,
Grant GT Steering Wheel, MSD HEI Coil, Taylor 8mm Wires, Leather 96 Camaro SS Seats,
Alpine CD+Changer,Alpine V12 Amps, Premier TS-1040C Subs, Polk Audio highs/mids.
Best ET: 14.94@91.67
High Speed Run: 157mph
WS6 Trans Am
Zepher
WS6 Trans Am
