Piston to valve clearance
I have a 84 Z-28 with a 350 in it, it has the Sliv-O-Lite Hypereutectic pistons with 4 valve reliefs in them a pretty much standard small block replacement piston. It has the Vortec L31 heads on it,I'am wanting to put a 268H extreme energy cam in it. The numbers on it are 224/230 at 50 with a 477/480 lift, the question is should I have any valve to piston clearance problem? It also has stock head gaskets and 1.5 rockers. I don't want to have to pull the heads if I don't have to, it will save me money as well as time! The heads were just put on the car 3 months ago. I would really apprecate some imput. Thanks NORT
Car: 4
Engine: 6
Transmission: 5
No problem.
The retainers will hit the valve guides at about .500" of lift. You are therefore well protected against ever having one valves hit pistons.
ICON Motorsports
ICON Motorsports
New2Chevy
09-28-2015 12:35 AM
355tpipickup
09-13-2015 11:35 PM
