Running Rough at 1800 rpm
Car: 1993 Camaro Z-28
Engine: 5.7l LT1
Transmission: 6-speed
I have a 93 Z-28 LT-1 that runs rough at 1800 rpm. Up to 1500 and over 2000 rpm it runs fine. I changed the plugs, plug wires, and brought it to a mechanic who connected it to a computer and said the electrical is fine. Could a partially clogged injector cause this?
Disconnect whatever controls your EGR valve on an LT1 then fire it up and see what happends. The EGR solenoid on my 89 caused a severe stumble from 1100- 1800ish rpm...after that it pulled perfectly.
Engine: 5.7l LT1
Steve, could you give me any help on locating the EGR solenoid on my engine? I've never had the opportunity to fight with one of these yet!
Engine: 5.7l LT1
update
I found where the exhaust travels from the manifolds to the intake. In that line, there is a block with a little white tube poking out the bottom. It looks like a vacuum(?) line or something should connect to it but I can't find anything disconnected. Any ideas?
eightsixseven
08-14-2015 03:09 PM
