to high oil pressure ???possible???
Car: GTA WS-6 1989 fully loaded
Engine: 1995 9C1 LT1 police pak XE cam
Transmission: t-5 borg warner
hi i had a 305 stock before.id died 3 time and i made it rebuilted 3 time.and i change my oil gage because it was always on top. i buy a mecanical gage and still does the same thing when i push the gas the pressure raise to the top why?? normale??
It's a cam driven mechanical oil pump, so as RPM's increase the oil pressure will increase as well.
Excessive oil pressure would be around 80psi or above. It will lead to bearing erosion and an early end to your engines life. What kind of pressure does your mechanical gauge read?
Owned- He's from montreal, English might not be his primary language.
ambainb
04-25-2016 09:21 PM
