knock sensor and spark module ?
Car: 89 trans am
Engine: 355
hey guys... if your knock sensor and spark module is setting your check engine light on how much will the 2 effect how crappy your car runs?
1 Post
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
A bad knock sensor makes your car run TERRIBLE!! Don't ask me how I know that.
Axle/Gears: 9-bolt/3.45
But if you're like Adam, you've got the pedal to the metal ALL THE TIME! So as soon as you get a ping from putting a heavy load on the engine, the computer will try to retard the timing. But it won't be able to, so it'll shut you down to "limp mode." And no man likes "limp mode!"
