Does FIX-A-FLAT really work??
U just put a can in my almost bald left front tire that has a slow leak(gets 1/2empty in 2-3 days)I cannot replace my tires for at least 2 ,ore weeks,do you think it will stop the leak??It didn't seem to inflate it much and I USED A WHOLE CAN!!
86 IROC,canary yellow(originally black),fully loaded.305TPI WITH 700R4/SHIFT KIT,3:73 POSI REAR,4 WHEEL DISC BRAKES,T-TOPS,POWER LOCKS,POWER WINDOWS,TILT,CRUISE,SADDLE INTERIOR,POWER ANTENNAE,SPOILER OFF 87 IROC SO NO THIRD BRAKE LIGHT ON ROOF,16" BY 8" RIMS OFF 89 IROC,3"INCH EXHAUST WITH A 2 CHAMBER FLOWMASTER AND 3 1/2" BY 18" LONG CHROME TIPS,20% TINT ON SIDES,HATCH AND T-TOPS,GTS TAILLIGHT COVERS,AFTERMARKET FOG LIGHTS,PIONEER 180 WATT CD RECIEVER AND DETACHABLE FACEPLATE,WITH JENSON SPEAKERS ALL AROUND,TALKING RADAR DETECTOR"BACON ALERT"
....Long live the EIGHTIES!!!and my love for the IROCZ
Yea it will work but it throws your balance way off and when you go to get them replaced the guy changing them will be cussing you and probably will charge you alittle extra for having to remove all that stuff. They did me.
'87 Trans Am
305 TPI:
160 Degree Thermostat
TB Bypass
Accel 300+ 8.8 Racing Wires
Accel Super Coil
Bosch Platinium Plugs
Custom Ram Air with K&N
'87 Trans Am
305 TPI:
TB Bypass
Accel Super Coil
Car: Death Mobile
Engine: 666 c.i.
It depends on the nature of the puncture. For a small nail in the tread, I have found it to work well.
You have to follow the directions on the can very carefully: use the whole can, and then drive about 5 mile to get the sealant uniformly inside. Then go to a service station and fill it back up with air.
If you see the item that has punctured the tire, do NOT take it out. It actually helps with the sealing.
Lastly, when you take the tire to get fixed/replaced, make sure you tell the tire shop. The tire has a flammable/toxic mixture in it now. You need to warn the repairman.
Also, make sure that you completely shook the container and I believe you have to empty it upside down when filling the tire.
On a completely flat tire, there is enough air in the can to give you about 10 psi. It is JUST enough to drive a few miles to get the "glue" applied equally to the inside of the tire.
Car: 04 GTO
Transmission: M12 T56
Oh god, reading something like this absolutely scares me. If your tire is almost bald and is loosing air because of it then it is way past it's service life and could fail at any time possibly hurting you and anybody on the road with you. Then you put fix a flat in it. They're gonna love you at the tire place.
...ed
...ed
1 Post
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
Ed, I agree 100%! Buy a new freakin tire, but a good used tire.
Rob P
89RSconvtZZ4TPI
Edelbrock Hi-Flow Intake
SLP Dual Cold Air Intake
1 5/8" Headers
Semi-Siamesed Runners
MSD6AL/relocated MAT/ AdjFPR/IROC frnt@rear swaybar/wonderbar/steeringbox/alum drvshaft/ Alston SFC/3:23posi disc rear/MAC LCA/H.Adams Panhard Rod/KYB struts/ shocks/
92Z28convt5spd
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
Rob P
89RSconvtZZ4TPI
1 5/8" Headers
92Z28convt5spd
Car: 82 camaro SC
Ever seen a guy smoke while letting the air out of a 'fix a flat' tire. It's not good. Please tell the shop that you put that **** in the tire if you do decide to use it.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
82camaro
1 Post
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
ive got z28 wheels that were chromed.air was leaking around the rim so i put some fix a flat(i do'nt remember what brand)in.worked good for awhile but starting leaking again.i took the tire to a tire place and found out that it had removed large pieces of the chrome AND aluminum. it also ate around the valve stem.
Works great!! A note on the replacing tire thing ....... Come on guys, give him a break. Like in my case - a new tire for the lawn tractor was more than it was worth!! :lol
p.s. Not that I should have to say this, but you never know. I'm being sarcastic.
Barry Izold
89 T/A, GTA
Modified 350/T-5
[This message has been edited by GTAMAN63 (edited March 16, 2001).]
Barry Izold
89 T/A, GTA
Modified 350/T-5
I HATE FIX A FLAT. That crap gets all over the place when you dismount the tire. It gets all over your hands, floor, etc. It's a pain in the as to clean up too. I can see using it in an emergency or for smal punctures, but I'm tired of people using that crap to fix 8 inch sidewall cuts and separated tires. Sorry, it's one of the things that just pisses me off.
82 Camaro:
350, Erson cam, ported heads, Crane Hi-6 ignition, Accel supercoil, Comp Cams 1.6:1 rocker arms, Turbo 350 tranny with 2500 stall.
82 Camaro:
I wish I could see this jalopy. It's cars like this that make it so when I tell people what I drive, they just shake their heads and try to imagine the hovel I live in. I'm guessing you're leaking air cause you've managed to wear the tire down to the steel radials. I'd go with duct tape and a can of oven paint.
<font face="Verdana, Arial" size="2">Originally posted by Steves ZZ5:
This post is scaring me. That fix-a-flat <font size=1>S</font>hit should be outlawed.
[This message has been edited by Steves ZZ5 (edited March 16, 2001).]</font>
"Sad thing is I missed out on some action that night."
WTF? When there's action to be had, nothing else exists! You dump in the fix-a-flat, and let it work while you "work"... i gotta teach you guys everything???
-Rich
-Rich
1 Post
Car: 91 Red Sled
Fix a flat is a mess no question, that's kind of how the stuff works! I don't expect to ever use it on my car. I'd much rather just use the AAA card. If I'm on the high way then yeah I'll use it but that is the only time. I used it this summer on my grand marq, worked great and I don't plan on changing the tire any time soon. I don't understand why some people hate it so much, it does it's job and is better for your car than the small donut (especially if you have a posi).
What is with people being so cheap that they won't even get new tires AFTER the old ones start leaking BECAUSE of the lack of tire tread. I'm sorry but that is just as bad as DWI. You're tire is more likely to blow out than anybody elses and you might loose control of the car and hurt somebody.
, Jon (in process of installing new engine)
Car: 88 Firebird WS6
In the last few years, because of the flammability prob, all inflate tire sealers are now using non-flammable propellent.
Ummmmm....I think that all Thirdgen F-bodies from 1982 thru 1992 came with what's called a "Spare Tire". I may be wrong, but I THINK that it's that big-*** round lookin' thing in the passenger side rear compartment of Thirdgens......Or maybe that's for better weight distribution while were drag racing......Correct me if I'm wrong please....
i dont carry a spare tire but i always carry fix a flat i try to keep good tires on my ride so i havent needed it yet
1992 camaro RS
195cc AFR heads with compition port work milled to 58cc "10.9 to 1 compression"
373 10 bolt rearend
ssm sfc's
87 350 TPI
bored 30 over
compucam 2032 with 1.65 full roller rockers
497-510 LIFT 214-220 duration
msd6AL
1 5/8 headman headers
2 `1/2 flowmaster exuast
k&n filters gutter air box gutted maf"no fins no screens"
3 pc under drive pulleys
no emissions no egr etc
custom ED Wright chip
eddelbroc intake base and runners ported plenum
accel 8.8mm wires
B&M mega shifter
gutted maf/airbox
hotchkis lower control arms
3" exhuast cutout
homemade cold air intake
2000 tci stall
700R4 with B&M shift kit edelbrock water pump
new best ET 13.5 @104.66
no times with new afr heads hoping for 12's on motor
Nos to be installed soon
1992 camaro RS
373 10 bolt rearend
ssm sfc's
87 350 TPI
bored 30 over
msd6AL
accel 8.8mm wires
B&M mega shifter
gutted maf/airbox
3" exhuast cutout
2000 tci stall
Car: 2000 Camaro SS
Engine: LS1 V8
Transmission: 6 Speed
Yeah dude, that stuff blows big time. I would only use it for emergencies, like when your in the desert and 20 or so miles from the next service station. Then you use that crap. And if you are looking to buy tires, I just bought from www.tirerack.com Bridgestone Potenza RE910 tires and dude, they kick *** .
It's been raining out here a little more than usual and those tires are awesome. I never slip unless I really want to
Well good luck,
John
Well good luck,
John
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Don't any of you guys have the CO2 canister? Just go buy a tire fix kit in Wal Mart and toss it next to your tank, it'll fix 90% of the stuff you encounter, AND you ahve the stuff to plug your tire yourself!
Terrell351
06-13-2021 01:13 PM
