GM 1.6 vrs Crane 1.6?? Machined trunnion??
I guess the GM don't have this machined trunnion. Is it needed to be done to fit the bowtie on my LB9? What is this machined trunnion anyhow? Thanx.
To fit the bowtie ? Since when is GM putting bowties in their engines ?
92 Z28 5.7
Trick Flow 23° heads, Comp Cams XR270HR-10 cam, Accel intake base + ported TPI,
TES headers, Flowmaster catback, MSD ignition, #24 SVO injectors, 1LE aluminum driveshaft.
Click here to see pics of my car.
Check out our car club Truspeed
Check out the Bin Archive for all your .bin needs
92 Z28 5.7
the trunnion is the machined, needle bearing, pivot point. if you have a stock, or more of less stock lb9 you don't need the high dollar rockers, you don't even need roller rocker. if you want to go from 1.5 to 1.6 you might see .025 more lift at the valve and very little preformance increase, if any. what are you calling a bow tie? the lb9 isn't a bow tie block, if thats what you're thinking.
ICON Motorsports
1st & 3rd
ICON Motorsports
1st & 3rd
Car: 92Z, 96RamAir, 91 4X4 Burb
Engine: 383 Super Ram, LT1, 350 roller
Transmission: 700R4, Probulit 700R4 &4L60E, 4L80E
I've got both a set of Crane Gold self aligning and GM self aligning rr's. The Crane Gold 1.6's and the GMPP 1.6's are made the same. The only diff is the GM ones have the bowtie emblem on the end and are clear anodized. Crane also makes the LT4 blue 1.6's for GM.
KevinP92Z
92 Z28 383 SLP cam,SLP headers,SLP 2ontheLeft,Trick Flow TW heads & pistons,Edelbrock base,Accel SuperRam,52mmTB,Scat Crank & forged ConnRods,MSD 6AL,SLP convertor,Baer 13/12" Track,Moser axles,Hotchkis,Genuine GM 3.42s,SLP HD Torsen,17x9" chrome SS rims
96T/A w/SLP Ram Air,SLP 2ontheLeft, Bilsteins, Baer, Hotchkis, Genuine GM, Torsen
76 4X4 Blazer 400TPI project
KevinP92Z
comp cams makes two roller rockers for gm SA applications pn 1318 1.6 and pn 1317 1.5. lighter and stronger than crane rockers and come with needle bearing trunnions.
ICON Motorsports
1st & 3rd
ICON Motorsports
1st & 3rd
UltRoadWarrior9
04-28-2020 10:39 PM
Hotrodboba400
12-10-2019 07:07 PM
bigjay89gta
10-15-2015 08:04 AM
