Stripping paint and grime from engine
Former Sponsor
Car: 1992 Camaro RS
Engine: Yet another 350 TPI
Transmission: Borg Warner 6 spd
Alright, tomorrow morning I am going to spray engine degreaser all over a 350 TBI longblock that I picked up. I'll rinse it off and that should take care of all the dirt and grime. I would like to paint the block though, as the factory paint is faded in most places. What can I do to prep the block or strip the old paint off? Aside from hot tanking the block, or sitting there with a drill and wirewheel for a couple of hours, is there anything I can do to strip the paint?
1 Post
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Originally posted by ME Leigh
Easy-off Oven cleaner!
Car: 1989 C4
Axle/Gears: 307
I third the oven cleaner. It doesent even matter which brand either. You could use dollar store crap and it still works great.
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
ive always used brake cleaner and never had a problem removing the toughest old paint or grime thats built up on an engine ....ive also used oven cleaner and had awsome results just make sure you dont eat your seals or gaskets up ....it sucks ...to have that happen..
What would work well safely for the motor of a daily driver. I think I had a power steering fluid leak, and there's gunk on the hoses and on some of the front end parts below. I would like to get it cleaned off.
Former Sponsor
Car: 1992 Camaro RS
Well, I had spoken with KingTal0n about it, and I ended up following his advice. I sprayed the crap out of it with engine brite degreaser, scrubbed everything with a wire brush, rinsed it off, and did it again. When it was clean, I dampened a cotton rag with pure acetone, and rubbed the whole block. Then I just went ahead and painted the block. Came out very nice, and the paint looks like it stuck very very well. I'll see if I post some pics when I get a chance.
kah992
08-19-2015 02:55 PM
