T5 transmission fluid drain and refill procedure >
Whilst I was changing the oil in the RS, I checked out the rest of the undercarriage. (My uncle has a pit )
Anyway, I'm clearly losing ATF slowly from the tailshaft/driveshaft seal.
So sometime soon, I gotta change that seal, and refill the tranny.
As far as draining the fluid, I don't suppose removing the input shaft will drain it all, I know there is a fill plug, how about a drain plug?
And one more question, the haynes manual isn't clear, it says to lubricate the rubber lip of the seal with ATF, and use "sealant" on the outer seal lip.
I know on an auto tranny, you use grease on the front seal in order to stop it from burning up.
Will the ATF suffice on the tailshaft seal?
And what do they mean by "sealant" on the outer edge, silicone?
I'll write a tech article on this, it's a fairly common question, with few answers available. (I already searched it )
Shane McConnell
macgyver@nethirdgen.org [*]Webmaster of www.NEThirdgen.org[*]1991 RS 305 T5 15.6@88[*]1979 Z28
Shane McConnell
if i remember correctly there should be a drain plug in on the bottom of the trans. i think it's a square head pipe plug, it'd been a while since i saw a t5.
ICON Motorsports
1st & 3rd
ICON Motorsports
1st & 3rd
Car: 4
Engine: 6
Transmission: 5
ede is right, there's a plug down low on the pass side.
You could lube the seal with anything. Motor oil, grease, ATF, spit... it doesn't matter, as long as there's something there to kepp it from burning up until some of the fill fluid gets back there.
ICON Motorsports
ICON Motorsports
That's what I was thinnking, I should have paid better attention when I was staring at that.
I gotta rust-proof the floorboards.
But anyway, I'm curious as to the sealant and lubrication of the seal.
Do yourself a favour and be careful with those bolts. Use the lower one to drain the fluid out then plug it up (DO NOT USE TEFLON TAPE or anything like that to seal it..you'll crack the case). I had to get mine welded after I cracked mine right around the thread. The best way to get the fluid in is to use and old fuel pump from the yard (that's what I use...or a washer pump would work great to). Worse to worse, a squeeze bottle will have to do. Let it drain well. (remove the drive shaft to get the last drops out the back). I like to replace the fluid from the inside of the car...it's much easier BUT, you have to know how much to put in before hand. (using the side bolt, you can fill until it starts to flow out of it..then you're done). Filling from the top is easier though, I've done it soo many times I can get the center console out in 5 min with my air ratchet.
89 GTA G92
305 TPI WC 5spd w/3.45
Accel Cap & 8mm Taylor's
Custom 4" Cold Air Induction
Jet Airfoil
K&N Airfilter
160 deg stat/fan switch TB Bypass - Steel Rad
Cat back 3" Exhaust w/Terminator Muff.
HiGh FlOw Dynomax Cat
Spohn LCA's - KYB GR-2's
Moroso Crank Bolt and roller pilot bearing.
Autometer Vac+Oil Temp
89 GTA G92
Jet Airfoil
K&N Airfilter
Filling it up is a PIA. I usually take the shifter off and pour it in from the top. Next time though I'm making a little contraption that will fill it without me even getting my hands dirty.
What I'm going to do is get a schraeder valve from a bike tire and glue it onto a large bottle. Then I have a hose that runs to the bottom of the bottle with a 10 foot long piece of clear rubber hose. Then I simply hook up the electric bicycle pump and watch it pump the fluid right into the tranny
[img]www.geocities.com/divx_edu/tranny.jpg[/img]
[This message has been edited by Mike89GTA (edited March 16, 2001).]
I did it the hardway also a few times....then I got smart. First time I filled my T-5 I ran a hose to the engine bay into the fill hose and kept pouring. Second time I took the hose up into the car. Third time I noticed something a little strange....there was ATF under the shifter....you can just take the shifter off and pour it down there with the top one plug out, as soon as it starts pouring out the top, you're full. No hoses, not air compressors, no problem
1984 WS6 Hardtop Trans Am
Former L69 Car under restoration
1984 T-top Trans Am
4-bolt main 350, performer intake, headers, Holley 650, T-5, hayes clutch, dual elec. fans and 3.23's.
Daily driver and restoration
13.98 @ 101
1984 T-top Trans Am
13.98 @ 101
Car: 4
Engine: 6
Transmission: 5
They make little plastic pumps that you just screw into the top of a lube bottle... like $5 at auto Zone... puts a quart of lube in there in about 30 seconds
ICON Motorsports
ICON Motorsports
Hotrodboba400
12-10-2019 07:07 PM
