What are some free LG4 mods????`
I have an 84 Camaro with the carbed 305 LG4. Since my TPI project is far from being finished, I was wondering what I could do to make my LG4 Camaro a little faster very cheaply. I have already changed the timing a few degrees and I have a K&N air filter. What else can I do for free or dirt cheap? ANY help is much appreciated. Thanks.
1984 Camaro Sport Coupe - 73K Miles
5.0 Carbed LG4
COMPLETELY stock except for a K&N Air Filter
F41 Suspension Package
700R4 Tranny
3.08 Rear End
New Paint
Best 1/4 Mile Run:
16.760 @ 80.74 MPH
Coming Soon:
350 TPI
Complete 3" Exhaust System
Aluminum Drive Shaft
3.27 Disc Brake Posi Rear
5.0 Carbed LG4
700R4 Tranny
3.08 Rear End
New Paint
Best 1/4 Mile Run:
16.760 @ 80.74 MPH
Coming Soon:
350 TPI
1 Post
Car: 99 Formula
Axle/Gears: 342
This isn't cheap, but since you are getting a 350 anyways, why not get a set of TES Edelbrock headers for $300, this will definately get your hp up. The headers will bolt right up to the 350.
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
FLOWMASTER
EDELBROCK 600CFM CARB.
KN AIRFILTER
UNDERDRIVE PULLEY
ACCEL HEI DISTRIBUTOR
2:73 GEARS
'86 IROC
GM GOODWRENCH 350
FLOWMASTER
KN AIRFILTER
UNDERDRIVE PULLEY
2:73 GEARS
There are a few tech articles on cheap mods for your q-jet in the tech section. You definitely should look into converting your air box to a dual snorkel unit, there is a good article on that too and it's very cheap. That would probably be the most noticable increase.
Car: 04 GTO
Transmission: M12 T56
On the cheap, make a poor mans open element, just cut some windows in the air cleaner.
Although not free, changing the secondary metering will wake you up a little more. A 'B' hanger is only a couple bucks from edelbrock, CK rods are only like $7. If you ask opinions on the carb board, a lot of guys will advocate the DR rods. They're nice too, prolly abetter match for an LG4, but also a smidgen harder to track down, you'll actually need to find a GM parts counter that isn't stpid, and they cost a little more. The CK / B combo could be at your door from jegs for like $15.
Also, if you haven't done so, you can reduce tension on the air valve (doors over the secondaries) so they open faster (see tech article) This works best with better secondary fueling.
Depending on emmissions and the timetable of your TPI project, you can go ahead and take all the AIR stuff out of the engine bay, saves you weight, looks 100x better and is equally easier to work on.
Other than that, keep up on the little things, keeping your tune-up fresh, etc. Synthetic oil is worth a little HP and effieciency, but you'll have to weigh the cost vs. minimal gain of course if you get bored before your swap, headers would be useful for your future combo. You can get a cam for well under $100 and get as funky as you want with it, CCCS is very tolerant of, well, everything. That rear you're planning will also help out. You could also get some roller rockers, as they can be used on your next engine as well
hope that gives you some ideas.
...ed
Ed Maher - Moderator @ The Carb Board
92 Z28 Convertible - Quasar blue / Tan top
LB9 4L60 GU2 G80 - stock, soon to be sleeper
-=ICON Motorsports=-
- Definitely prototypes, high powered mutants of some kind. Too weird to live, too cool to die
[This message has been edited by Ed Maher (edited March 13, 2001).]
...ed
Hotrodboba400
12-10-2019 07:07 PM
