I Want Torque!!!
I Want Torque!!!
I am looking for an engine that has lots of low end grunt and lots mid range power, I don't plan on going above 5500 rpm. I would like to use Vortec heads because of price and from what i have been told them producing good torque but my question is with they work with a TPI setup and will the ZZ4 cam work with it too? What do you think of this setup. Anyone want to run it on a desktop dyno?
1989 L98
1) 3" Cat-back, Flowmaster
2) Hooker 1 5/8 headers
3) GM Vortec Heads
4) ZZ4 Cam or one like it
5) enought work to the TPI system to get it to work right. I don't know exactly what I will have to do, but if i have to port it then so be it. I will also install all the little things like K&N, an airfoil, wires plugs ect.
1989 L98
3) GM Vortec Heads
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
<font face="Verdana, Arial" size="2">Originally posted by camaro6spd:
1989 L98
3) GM Vortec Heads
Thanks</font>
1989 L98
3) GM Vortec Heads
Thanks</font>
Saw an article on those Vortec heads recently. It said they come with crappy springs and press in studs. You'd definitely has to address those two areas using the ZZ4.
Jake
1986 Corvette Coupe, 415 CID, Edelbrock 6073s, ZZ9
ok in my opinion,, the vortecs suck!! they flow yes,.. but, like the other guy said.. they have very weak springs and lousy studs!! now honestly, for the money(and they are a bit pricy!!) i got the 64cc 200intake sportsman 2's F*** they are awesome came assembled with 2.02 1.60 valves screw-in studs and guide plates!! and not pathetic brands,, how about comp and manley!!! for the money save a little more ans get the sportsman2's they are the SHI* read my sig i just finished the car and whooo does it have the ponies!!!it pulls extremly hard to 6,000 rpm's!!!! and the cam dies at 5600!!!and it wanted more!!!! themodule is limited to a plug-in of 6,000 also!! do the mods i have and you will NOT be dissapointed!!!around 400rear wheel hp and 450lbs of tq!!
89 firebird formula
356 10.5:1compression
comp cams xe262 cam
performer rpm intake
#1405 edlebrock 600
sportsman 2 heads 64cc 2.02/1.60 valves 200cc intake runner
msd 6al
h.e.i. proform 50,000 volt vac. advance ditributor
700r-4 with 3.08 first gear and 3.23 posi 7 5/8 rear end.
b trans shift kit(will kill shifts...suck dong!!)
shorty heddman hedders with custom 3" pipe y-pipe back(no damn cat!) with 40 series flowmaster!
future mods: 406 roller REALLY REALLY REALLY RADICAL!!!!!
89 firebird formula
comp cams xe262 cam
#1405 edlebrock 600
msd 6al
Ok, thanks for the informatin on the vortecs and I think I will change my mind on them unless some people have so damn good success stories. Also, can anyone give me BOLT ON mods for the TPI system. Some has to have around 400 ft/lbs with the TPI. I really don't want to go above 415 because the T-56 is rated at 450 ft/lbs. Also I don't want to hear about NOS or a turbo or super charger. I don't like NOS and the turbo or super is out of my price range. What do you think is better, Sportsman II or GM Fast Burn.
no green
01-09-2016 09:22 PM
