Trans. shifts hard
Car: 06 Toyota Tundra SR5
Trans. shifts hard
I have 87 Firebird 305 LG4 engine, and I was wondering, cause it has done this ever since i bought it, was after I started up my car, let it warm up, then I put the shifter into Reverse and half a second later, it will shift really ahrd and jerk the car and I think the tires spin a little, but I know its not me cause I hold te brake down hard. Someone told me that a "U-joint" or clamp might be loose and thats waht is doing it. Is this what is wrong, help, thanks.
87 FireBird Formula
305 4bbl LG4
K&N Filter
Flowmaster 80 Series
3 inch tips
Holley Quadra-Jet 650 CFM 4bbl Electronic Carburetor
"General Tires" P215/65R15
-----Need Upgrades-----
--Give suggestions plz--
http://members.tripod.co.uk/michigan34/car.html
87 FireBird Formula
305 4bbl LG4
K&N Filter
3 inch tips
Car: 1991 GTA Convertible
Your trans may be going or the engine might be idling too high for it to go into gear smoothly. Does it do the same in Drive? If it does, check your idle RPM in park or Neutral. It should be anywhere between 700 and 900 RPM's. If the idle is normal than you can adjust your Throttle Valve Cable. Loosen the tension a click or two and take it for a test run. This does not sound like a loose u-joint.
1988 GTA 5.7L TPI Auto
355 ci. block, SLP Cold Air Intake w/ K&N, fully modified MAF Sensor, TPIS 52mm Throttle Body w/Air Foil, Fully Ported and Polished Plenum, Nikel-plated Ported SLP Siamesed Runners, Ported TPIS Big Mouth Intake Manifold, stock heads w/ 1.52 Comp Cams Self-aligning Roller Rockers, TPIS ZZ-9 Roller Camshaft, TPIS Valve Springs, Cloyes True Double Roller Timing Chain, TPIS Adjustable Fuel Pressure Regulator, Ford Motorsports SVO 30 lb/hr Fuel Injectors, MSD 6AL, Taylor 10mm Wires, Bosch Platinum +4 Spark Plugs, MSD Blaster Coil, MSD Shift Light, March Underdrive Pulleys, 6 3/4" Vibratech Streetdamper, TPIS Level 4 PROM, 160 T-stat, Low Temp. Fan Switch, Stock Distributor w/ Bronze Gear, SLP 1 3/4" Headers, Random Technologies High Flow Cat., Adjustable Borla Cat Back Exhaust, Flow Tech Pre-Cat 3" Exhaust Cut Off, ZR1 Heated O2 Sensor, Level 10 PTS-3 700R4 Trans, B&M Holeshot 2400 Stall Converter, B&M Trans Cooler, TCI Aluminum Finned Trans Pan, Torque Converter Lock Up Switch, 3" Balanced Aluminum Driveshaft, 3.73 Richmond Gears, Auburn Pro-Series Differential, Aluminum Differential Cover w/ Main Cap Preloads, BF Goodrich Drag Radials 255/50 R16, Hotchkis Lower Control Arms, Hotchkis Panhard Rod, Hotchkis Tie Rod Adjuster Sleeves, Bilstein Heavy Duty Shocks and Struts, 1LE Springs, Energy Suspension Polyeurethane Bushings, Global West Tubular Subframe Connectors, Global West Steering Box Brace, HP Motorsports 3 Point Strut Tower Brace
"Why ride a stang when birds can fly?"
http://www.geocities.com/thegta
[This message has been edited by Joseph Andres (edited March 12, 2001).]
Breazlan
09-25-2015 11:20 AM
TheTraut88
09-07-2015 05:22 PM
