Noise on my friends 3.1 LHO motor from 91' camaro
After he starts up the car he hears a ticking sound. It happens once and awhile. He just changed the oil and im sure thats not the problem but the noise sounds like tick<knock> tick<knock> sound sort of combined but after the car is warmed up and has been driven it stops making that noise. Im sure the prob. is internally but what can be causing that noise and how can he correct that problem. Any guesses.
92' camaro
New 305 block TPI conversion, Flat top pistons,Bore over .30 Forged parts all around,Edelbrock intake,ported plennum,ported corvette alluminum heads, accel cam,52mm throttle bodie, SLP runners Home aid cold air induction, Air foil,ford SVO 19lb injectors,fuel regulator,cloys timing chain, comp alluminum roller rocker arms and pushrods MSD 8.5 mm wires, bosch plattinum plugs, hypertech cap & rotor and coil, Edelbrock TES headers, free flowing catalytic converter and a 3 inch force II flowmaster exhaust system, and a 3 inch cutout,Zoom multi friction clutch, T-5 tranny,billenstien shocks&struts.
Soon to come!!!
Procharger system 12lbs o boost.
New paint job(hawaiin orchid purple)Cast alluminum ZR1 rims w/ 275 tires.
Favorite quote: "where ever u go, there u are"
Other car;
1971 plymouth Duster
Mods:340,edelbrock victor jr. intake, 650 4 barrel holley, heddman headers,40 series dual flowmasters, cold air intake,4:10 gears, just got a new paint job and cragar rims with 315 tires in the back.
:Yeah its not a chevy but damn how many 71' dusters have u seen in the streets.
92' camaro
Soon to come!!!
Other car;
Thats kind of funny.. I was getting that a while ago but it went away. One time, ONE! time I took my car to Chevy to have them fix it, came back with a vacuum leak and this wierd ticking sound. It went away after a week or so, I just forgot about it.
This is probrably Not what You guys are hearing, But...
This girl I know has a 91 3.1L, and it was making a weird Ticking noise, So i took a Look at it for her.
Turns out that The Alternator Pulley/fan was hitting Both the alternator houseing and The Serp belt, dont ask Me Why.
A little pleir work and it was all straitend out, but It wast very obvious at first.
maybe that helps
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver
Just another Hot Rod kid, or thats what they all tell me.
Livin' the Stereotype
maybe that helps
theshackle
09-17-2020 08:26 AM
