Tech article is wrong
1 Post
Car: RS
Axle/Gears: 9" for the ladies
The tech article "how to redo your brakes" has the wrong tool listed. A 10mm hex wrench will be too big. You need a 3/8 inch hex wrech.
1 Post
Car: RS
I tried over 30 thirdgens and it will not fit on ANY. I ground it slighty smaller with a sander and it still wouldn't hammer in.
Autozone or anyplace sells a 3/8 for $2
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
It definately is a 3/8", and when you consider the dirt and grease that ends up in there, something that is slightly bigger that would otherwise work, probably won't in this case. At least it isn't that piece of crap T-60 torx that they use on the "W" body cars that seizes up like crazy!
Working on:
'84 Z28 LG4 305 with 200,000 original miles!
Added dual elec fans.
145 MPH IROC Speedo
Building 430 HP 350 (ZZ430)
using primarily GMPP parts.
Short block sitting on a stand.
Starting to look like the Kicker poster child!
ASE Certified Master Tech
Working on:
145 MPH IROC Speedo
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Ha! Out of all the metric/standard sizes that are close enough to use either wrench, 10mm is the worst. I suppose you could use 10mm on a 3/8 but if it's 10mm then neither 3/8 or 7/16 will do. If you need to buy any metric tools, you must have a 10mm.
One metric size that never seems to be included in any basic kit is 18mm. There is no standard equivilant for it. Power steering lines on the GM steering box are 18mm and nothing else will fit.
I think the tech article should just be re-written to suggest a 3/8 or 10mm depending on what is required.
It's not the the T-60 seizes up, it's that the factory torques them to 400 pounds.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z Pro ET Bracket Race Car
383 stroker (carbed) with double hump cast iron heads and pump gas
461 Big Block installed and ready for the 2001 racing season
Best results before the 383 blew up
Best ET on a time slip: 11.857 altitude corrected to 11.163
Best MPH on a time slip: 117.87 altitude corrected to 126.10
Altitude corrected rear wheel HP based on power to weight ratio: 476.5
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Best 60 foot: 1.662
Car: 84 Z28
Well, I actually think it's the aluminum spacer that causes the problem on the T60, but I just hit it with the impact, and sometimes have to heat them, and they come out.
Skip, that is weird, because isn't 10mm bigger then 3/8"? 10mm comes out to .394", where 3/8 is .375". Oh well, I guess it's just a trivial thing!
Working on:
145 MPH IROC Speedo
Working on:
145 MPH IROC Speedo
Car: 1986 Firebird
Engine: 2.8 V6
I also use a 3/8" hex on my front & rear calipers... never had a 10mm one to try.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Car: 1994 Trans Am
Engine: 5.7L LT1
Transmission: 6-speed
The first time I re-did my brakes I bought a 10mm wrench as the article suggested, and guess what? It didn't fit. I went back and I noticed a brake caliper wrench for GMs. Sure enough, it turned out to be a 3/8" wrench. It fit perfectly too. No crud or grease build-up that was blocking the 10mm wrench - it was just a tad too big.
'88 IROC 305 TPI
Crappy 700R4 slushbox
Gutted airboxes
180 degree T-stat
Advanced base TPS voltage
Relocated IAT sensor
Momo steering wheel (gotta luv it)
Ram-air setup coming soon
Flowmaster muffler (puke)
Taylor SpiroPro wires
Accel cap and rotor
Ported plenum
Kills: '94 Z28, Olds Aurora V8, bunch of Mustangs, T-birds, ricers, and others who assumed a 12 year-old car would be too slow.
'88 IROC 305 TPI
Gutted airboxes
180 degree T-stat
Accel cap and rotor
Ported plenum
humph ........ american cars with metric bolts..............wtf....... im as confused as a baby in a topless bar...
1991 RS LO3
mods: 14" chrome air cleaner, straight-piped after cat exhaust with one chrome dual tip on the left side.
future mods: headers, removing smog equipment, and as many cheap mods as i can find
aol s/n: budman8503
GONE MUSTANG HUNTING.......
BACK IN 10 SECONDS
1991 RS LO3
aol s/n: budman8503
BACK IN 10 SECONDS
