?s about plenum porting
I was thinking going to port my plenum this week but I had some questions first. What do I grind out? Can i use an inline air grinder or do I have to buy some special porter? Do you have to buy special porting bits or can you use air grinder bits? What gaskets do I need to buy? How much more horespower will it give me? Does anyone have any pictures of what I need to grind out from when they did it? For the people who did it, did you notice a big difference when it was done? I know I asked alot of questions but any help would be greatly apreciated.
88 iroc
LB9 305 tpi
k&n, flowmaster, ADS chip
160* thermostat
home made ram air
removed smog pump
TB bypass
ASCD big block hood
88 iroc
LB9 305 tpi
160* thermostat
home made ram air
removed smog pump
TB bypass
ASCD big block hood
Car: 1989 Firebird Formula
Try this page for info on porting the plenum. It should help you:
http://www.tribal-treasures.com/cars...-port/port.htm
...or check this link:
Plenum Porting.pdf
If you need any more photos or details, just add to the thread.
Later,
Vader
"I'm'a do Things My Way - It's My way or the Highway."
Adobe Acrobat Reader
Plenum Porting.pdf
Later,
Vader
thank you very much. Those links were perfect.
88 iroc
LB9 305 tpi
160* thermostat
home made ram air
removed smog pump
TB bypass
ASCD big block hood
88 iroc
LB9 305 tpi
160* thermostat
home made ram air
removed smog pump
TB bypass
ASCD big block hood
