Do these TPS readings make sense?
Car: 1988 GTA
Engine: 5.7L/L98
Checked my TPS readings yesterday (see sig for car details), these are the best readings I could get. When I adjusted the closed throttle to .5V the best WOT reading I could get was about 3.6-3.8V. If I raised the closed throttle to .88 I could get 4.45V at WOT. This is where I left it. I also have a new sensor I tried just to see if there would be a difference, there was none between the new sensor and current sensor on the readings. At the highest adjustment I couldn't get more than about 4.5. Are these ok? Can the tab off the throttle body be adjsuted at all to get what I need or am I ok?
Car: 87 Pontiac Firebird Formula
Engine: 355 SBC-Thats all I can say or they will break my legs.
Transmission: 5 Speed
At WOT you don't want it to read anything highter than 4.5-4.7VDC max. If the computer sees it at 5volts it will set a code because the only time the senor should read 5 volts is when it is shorted to ground, and that means the sensor is bad. A good closed throttle setting is .45VDC
sorry, my mistake...good eye formula350_87. he is right. it would be shorted to ref. voltage if it was 5 volts, ground if it read 0v.
Car: 92Z28,91Z28,91Z281LE,95ZR-1,08Z06
Engine: 406, 350, 305, 350, 427
Transmission: auto, auto, 5-speed, 6spd, 6 spd
Axle/Gears: all stock
TPS adjustment
omcrider,
I will have a GRAND OPENING soon at my shop. There will be few 3rd Gens showing up. If you don't mind driving over to Sacramento to meet other 3rd Gen, I will help you adjust the TPS to have the best throttle response. No charge of course, gotta make it worth your drive.
Car: 1988 GTA
Engine: 5.7L/L98
Re: TPS adjustment
Originally posted by 1TUF92Z
omcrider,
omcrider,
Ooppps
omcrider,
Sorry I wasn't clear on my previous post. I just opened a new smog testing and general auto repair facility 3 weeks ago. And yes, I have the Snap-on scanner that we can use on your car. I'll post the date for the grand opening on the "West Coast" page. It should be within this month for sure.
Bennie C.
Smog Diagnostic Specialists
3100 ArdenWay
Sacramento, CA 95825
916-974-SMOG(7664)
Bennie C.
3100 ArdenWay
916-974-SMOG(7664)
mdtoren
08-16-2015 05:45 PM
