Car Eats Starters
Car: 91 Camaro RS 92 Camaro RS
Engine: 406, 305
Transmission: TH350, 700R4
Car Eats Starters
this is getting really bad, i've gone through 3 starters in 2 weeks, one of which got 2 starts out of it. the case on the starter keeps cracking. what is it? my car is not stock, and has headers. any ideas?
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
RB has reported issues with some 70's 350 blocks not having the mount bolt holes properly located.
Engine: 406, 305
yeah i'm using starter bolts, and i think it's a late 70's block with the NON offset bolt pattern. i think i know what it is but not for sure, maybe because the housing is too loose in the bellhousing? i bought a starter from summit, a mini high torque starter, i guess i'll see what that does.
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Re: Car Eats Starters
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
are your headers tight to the block? I had the same problem with a full size starter where it had a little bit of clearance to the header but when it would start the engine it would tighten up against the header and snap the starter housing. fixed it by adding a mini starter which had several inches of clearance as opposed to a cm or 2
db057
08-11-2015 10:11 PM
