JB Weld on Exhaust Manifold?
Will JB Weld stand up to the heat of sealing brass pipe plugs for the AIR system holes in the exhaust manifold? I think that may be where my leak is. Thanks guys.
Crap. I guess I could try it though since I was just going to tighten the plugs some and smooth the JB over them, so it won't have direct exposure to exhaust gases. I need to know the exterior temperature of the mainfolds I guess. Where's a temperature gun when you need one .
I cut the AIR tubes off my exhaust manifolds. Then, I ran some self-tapping bolts in the holes with a whole lot of JB weld inside the hole and around the edge. I had one blow out, but I put it back in with more JB weld. This was almost a year ago, and it's still holding strong.
82 Camaro:
350, Erson cam, ported heads, Crane Hi-6 ignition, Accel supercoil, Comp Cams 1.6:1 rocker arms, Turbo 350 tranny with 2500 stall.
82 Camaro:
make sure you use the regular jb weld...not the quick stuff, i think the regular hold about 600* while the quick will hold only 300* or soemthing close to those ##"s
350, Comp 262, Edelbrock Performer intake 600 cfm carb and exhaust, headers
-JVC, Eclipse, Pioneer, MTX, Phoenix Gold, Planet Audio
Good. The regular is what I have so I'll try that out. I checked the tightness of those brass plugs and it turns out I could run them in another 3-4 turns so I'm going to see how that holds up for now. Thanks guys.
Car: 4
Engine: 6
Transmission: 5
I seriously doubt it would work... get some exhaust cement / sealer, it should do the trick.
ICON Motorsports
ICON Motorsports
Hotrodboba400
12-10-2019 07:07 PM
86CamaroDan
09-29-2015 10:08 PM
