Very quick camshaft install Q
Car: '86 Z28
Engine: LB9 (305 TPI)
Transmission: 700R4 w/kit
I'll keep it short and to the point...
Do you have to remove the engine in our cars to install a camshaft or not?
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Nope, you just have to undo a lot of things including the oil pan. Is what i do, is i unbolt all but the last couple and for those, i leave them in, but very loose. That lets the oil pan fall down enough for clearance.
Yopu jack the car up, but the engine can remain fully bolted in.
Car: 4
Engine: 6
Transmission: 5
Right; you don't have to remove it, but if it's easy for you to do so, you may find that it makes the job as a whole faster doing it that way than leaning over it. It depends on your setup.
You'll have to remove the A/C condenser (which can be done without disconnecting or draining it by pivoting it and the compressor together as a unit up and out of the way); and remove or sodomize the bracket under the hood latch. Plus drop the oil pan a little bit and all that.
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
The only real problem I had doing the cam swap with the motor in my car was getting it past the two crossed front end braces. I could not for the life of me get them off so I just had someone pull them up slightly and the cam came right out. I also lucked out and didn't have to drop the oil pan.
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
i do it with the engine still in the car, it is fairly easy, last time i did it, i snuck it out without even removing the accessories.
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Car: '87 IROC-Z/'82 RX7
Engine: SBC 355/1.1L Rotary
Transmission: T56/5 Speed
Axle/Gears: 4.33/3.93
If you have a two piece rear main seal, you don't have to remove the oil pan. You do have to make a timing cover modification though.
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
I have a "tutorial" that I made when I did my swap. I answered a ton of my own questions actually performing it, as well as tons of help from TGO members. Thanks
https://www.thirdgen.org/techbb2/sho...hreadid=224633
Car: '86 Z28
Ok, thanks for the quick and helpful replies! I may end up removing the engine... I guess we'll see when u put in the cam
NinjaNife
08-23-2015 11:49 AM
