Speedo went :(
Speedo went :(
ok i am sure its gone, i was at 3.8k in third gear at WOT and it said 50mph. second tops around 70. also when i slow down it sits at 40 then al the sudden drops to 10.
where can i get a newone and whats the easyest way to remove it. i have never done it before and it looks like a pita.
thanks
-Stell
1988 IROC-Z 305TPI MINT!!
Mods= Accell SuperCoil, MSD 6A, Ported Plenum, No MAF Screans, K & N, SLP AirFoil,180 Thermostat+ Temp Switch, Relocated MAT, Cold Air. Soon to have Edelbrock TES Headers,MSD Ignition wires and a few other misc goodies
1988 Pontiac Trans Am. 305 TPI Beyond MINT Condition. Dynomax Catback
thanks
-Stell
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I have a 145 cable-driven Camaro cluster for sale, see my ad in the classifieds. You'll have to remove your cluster to either swap the new cluster in or to replace the speedo head in your old one. Remove the black plastic bezel, the metal guage overlay, the two nuts at the left and right bottom of the white plastic gauge housing. Drop the kick panel (and personally, I'd drop the steering wheel a quarter inch or so), then contorting yourself, snake a hand or long screw driver up behind the cluster and trip the little fastener that holds the speedo cable to the speedo head. The cluster should wiggle free at this point. I worked very methodically when I did mine and the whole procedure took, perhaps, an hour and a half.
JamesC
JamesC
