91 305TPI=205hp or 230hp
Car: 91 Z28
Transmission: 5 speed
Axle/Gears: 3.42's
What's the difference. They were both LB9 motor's "VIN F" Right? Which one's in my 91 Z28?
1 Post
Car: 1991 Camaro Z28 5.7 G92
Engine: L98 Tuned Port Injection
Transmission: TH700R4
Axle/Gears: 3.23 Posi G80
Since you have the 5 speed, you have the L98 cam in it stock which makes your 305 have 230 HP. The 700R4 LB9's got 205 hp. I read somewhere that if you drive your car perfect you could run dead even with an L98 auto or maybe take it.
Car: 91 Z28
Axle/Gears: 3.42's
That's what I thought, but wasen't sure. It's posibble that my car could hang with a L98, it did come with 3.42's from the factory, that might help. Thank's for the info.
Car: 4
Engine: 6
Transmission: 5
That's not the difference; although the cams are different at least in some years. There's some debate as to whether the cams were still different in that year, or whether they had made them all the same by then.
The higher HP cars have the G92 RPO which gets you, among other things, dual cats. If your car is single cat, it is the lower HP version.
They are both VIN F.
Car: 91 Z28
Axle/Gears: 3.42's
I don't think I've ever seen a 91 Z28 with a singal cat. My car has duel cat's. I think 89 would have been a year that you would see singal or duel cat's.
1 Post
Check your RPO codes in the center console of your car and input them into the forum decoder. I have 3.42's in my Beast and a T-5 and at 60 mph I am pullin about 1800-1900 rpm in 5th. Also if you have a 145 speedo then you have the 3.42's if it's the 110 version then you prolly have the 3.08's. If that doesn't work you could call a GM dealer and give them your VIN # and they could prolly tell you.
Car: 91 Z28
Axle/Gears: 3.42's
Got more info.
G92-axle,rear,performance ratio
GU6-axle,rear,3.42 ratio
and N10 is the RPO for duel cat's
I do have the 145 speedo, and these RPO's are all stuff I have on my car. I think that G92 is a little more then just different gear's.
I work at a GM dealer, that's where I got the info.
Car: 94 Z28
Engine: LT1 w/ headers, catback, CAI, tune
Axle/Gears: 3.23s
Supposedly the non-G92 305 TPI 5spds were rated at the same 205hp as the autos. The accepted info was that they got the crappy cam that the autos were usually stuck with. But several people here and at cz28.com have pulled the cams and spec'd them out to be the hotter cam. They would seem to be underrated pretty decently at 205hp in that case, dual cats vs single cats was previously a 10hp difference...
Now there are some thoughts that even the 91-92 TPI autos got the hotter cam too, not sure anyone has ironed that out with any certainty yet. But some of the stock 1/4 times I've heard reported for 91-92 305 TPI autos certainly make it seem quite possible...
Car: 91 Z28
Axle/Gears: 3.42's
Everything point's to it being the 230hp. That's not bad. Mustangs made 225 right? What kind of 1/4 mile times can I expect? Maybe a high 14(like 14.9) on a good run would be my guess.
Stell1579
Aftermarket Product Review
10-11-2000 10:47 PM
