Anyone with '89 Firebird body manual, help...
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
1 Post
Car: '84 Fiero ('01 GA interior)
Engine: '96 4.0 Aurora
Transmission: '96 4T80E
Could you please look up the 4'th gear switch . It should be in the engine wiring section along with the TCC switch. Does the manual show the switch Normally Open or Closed to ground? My '88 manual shows closed to ground, but the switch in my tranny is open to ground (closes in 4'th). Any help- out there?
TIA,
Bob
Bob '89 Formula CC350
Last(lost)Member of the Elusive Great Lakes Crew
My car's homepage
TIA,
Bob
My car's homepage
Are you talking about the 4th gear pressure switch in the tranny?
I'll look through the section you mentioned in my Camaro manual, should be the same as the 'Birds
1 Post
Thanx Mike, that's what mine shows. ('88). But I took it off and checked it, and it works the opposite way. Under pressure the switch is closed. If I looked at the hydraulic schematic right, that circuit only recieves pressure in 4'th. I think the ECM must invert it or something. Anyone know for sure?
thanx,
Bob
thanx,
Bob
1 Post
I'm using an Accel DFI system. Ever since I hooked it up the tranny would not lock in the right gear, so I disabled it thinking the switch was bad or miswired. Now that the tranny's out, I have a chance to look at it. The DFI is expecting a ground until 4'th gear in which the switch opens and the signal goes hi. (Just like in the manual). But the switch is actually open (hi) until 4'th. I thought it might have been a change between '88 and '89, but our manuals seem to be the same.
I'll hook up a relay to invert the signal. Thanx.
Bob
Bob
1992 Trans Am
05-10-2023 07:19 PM
Terrell351
06-13-2021 01:13 PM
colton_carlson
03-08-2019 12:21 PM
