power stearing high pressure line?
Car: 86 Camaro Berlinetta
I had my car looked at last week....
The guy said my power stearing high pressure line is leaking. How hard is this to replace? How much is the part? Is it a manufacture only part? And how long should this take and does anyone have any pointers/tips/howto's on this? Thanks.
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Call the parts store and ask them if they have one, and how much it costs.
If they have one, go buy it.
Take it home.
Put a catch pan under the car.
Use a wrench to take off the old one.
Use a wrench to put on the new one.
Start car, and fill resevoir as needed.
Pretty easy.
Take it home.
Pretty easy.
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
nope its only under pressure with the pump turning.. i think i paid 30 bucks for mine but that was a few years ago so i could be wrong..
ended up paying $40 for it to get it today....
Put it iin....took like 3 hours....
Couldn't get the line out of the back of the pump so I cut it with a dremel and unscrewed the bolt on the back of the pump put it back in nice and tight and put the new line in went in real easy. The person before me replaced it and used teflon tape on the line fittings......
took me like half an hour to get that end out of the bolt....
mdtoren
08-16-2015 05:45 PM
TA8487
08-16-2015 12:21 PM
