Pro Topline Vortec Heads
Car: 91' Camaro
Engine: Carbed 305
Transmission: 5-Speed Manual
they say, the heads come with LT1 springs. Does someone know the specs of these springs? and i have seen somewhere, that the lt1 springs are too weak for use with 1.6 roller rockers. is this true?
thanks,
nebu
thanks,
nebu
the rocker has nothing to do with what spring you run, the cam does. match the springs to your cam specs. i'd buy springs from comp or lunati.
You can custom order them with the spring that suits the
job at hand.
If you read the ad "they" recommend that.
You can get the proper spring recomendation from the cam manufacturer.
job at hand.
84z96L31vortec
08-20-2017 12:16 AM
L98GTA87
08-11-2015 06:55 PM
84z96L31vortec
08-10-2015 08:27 PM
