How does compression affect cam choice?
Car: 1986 Iroc-z
Engine: Soon to be 350
Transmission: 700junk4
Ive heard that how high or low your compression is will affect the kind of cam you choose. Could any one confirm this and explain exactly how it works? i plan on using an lt4 hot cam with my motor, which currently is at 10:1 compression. Would there be a problem with this or is there a better cam out there for this compression? Any input would be appreciated.
Thanks,
Dane
Thanks,
Dane
1 Post
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
I have heard that you should run a higher duration for higher compression engines so you can tame detonation. Again, this is just what ive heard, if you do a search, im sure this has been brought up before.
1 Post
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
But, like I said, I'm not totally sure about that, its just the way I've come to understand it.
1 Post
Car: Z28
Engine: Sb2.2 406
You should be fine with that compression. Remember the HOT cam was designed for use in the LT-series engines. Stock, those run around 10:1 compression.
as for the duration vs compression, i think the BEST way to say it is that they go hand-in-hand. And yes, as you raise the duration (assuming the LSA is a constant), the overlap increases. My cam is a perfect example.
Don't choose a cam based on the compression ratio.
Or to "tame detonation".
Don't try to run a motor with a high compression ratio by over camming it. thats a bandaid solution that makes for an inefficient motor.
Choose a cam that will work well with the induction and exhaust systems to make power (torque) in the rpm range you want to drive in.
Then; design your engine to be as efficient (compression ratio) as is practical, ( fuel grade {octane}, availability, cost).
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
You want to choose the compression ratio after you already decided on a cam, and exaust and ...
Meaning if your setup can only support a XE256 run 9:1 compression. If your setup can support a XE286 run 10:1. ETC...
You want the dynamic compression ratio around 7.7:1 for optimum effeciency without detontation problems.
Hotrodboba400
12-10-2019 07:07 PM
