How do I know if my rotor is shot?
1 Post
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I have an Accel Cap and rotor and MSD 6AL and the cap looks fine so goes the rotor but instead of the brass piece its black Normal?
Mine was a little black when it burned out. Just replace it. It's only a $5 part. If your car has been running like crap, mileage is half of what it normally is, and it acts like it's missing, it's likely to be the rotor.
82 Camaro:
350, Erson cam, ported heads, Crane Hi-6 ignition, Accel supercoil, Comp Cams 1.6:1 rocker arms, Turbo 350 tranny with 2500 stall.
82 Camaro:
Guest
Posts: n/a
It shouldnt be black. Black and/or green is carbon tracks.. Is it really burned where it contacts the center of the cap or just a little bit of black dust on there? If its just dust, try wiping it off and clean the terminals on the inside of the cap with a little bit of sandpaper, and make sure all the wires are on all the way.
If its burned bad, replace it.
the_hamturdler
09-30-2015 12:50 PM
