Weiand Stealth
Car: 1989 IROC-1
Weiand Stealth
Stupid question I'm sure...will my Quadrajet fit on a Weiand Stealth intake?
Car: 82 camaro SC
Some adapters have problems leaking and usually hurt performance. The stealth is pretty high, so you might have problems when you add a spacer. A holley will fix your problems if you have a stealth.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
82camaro
Car: 1989 IROC-1
Actually, the Stealth model 8004 accepts spread bore carbs......no spacer needed.
That's what I'll buy.
