About to weld on fuel tank sump, any pointers?
I already cut a big fark'n hole in the bottom of the tank. Are there any tricks to it? Just weld it over the hole, so the fittings are at lowest/rearmost point of the tank?
"American made baby. 100% American iron. The muscle among the masses. My hero. Yep, you can take your ergonomically designed, space age, computer controlled, 4 door, cup holding map lighted split double wishbone split fold down retractable cargo covered moon roof piece of transportation and keep it. For I have felt the thunder. And I know the difference!"
JSP Motorsports
ICON Motorsports
JSP Motorsports
ICON Motorsports
if i had it to do over i'd put mine on all the way to the right so i had more room for fuel pump and filter, but all i did was center it up and more or less all the way back.
ICON Motorsports
1st & 3rd
ICON Motorsports
1st & 3rd
too late jester told me on icq he's seeking profesional help on this one.
ICON Motorsports
1st & 3rd
ICON Motorsports
1st & 3rd
Yes, ladies, gentlemen, and ede, learn from my mistake. No matter how good you think you are, never try to weld steel that thin with an arc welder
Hope my weldign shop is willing to try and fix the holes I burned
JSP Motorsports
ICON Motorsports
JSP Motorsports
ICON Motorsports
Jester,
Don't feel too bad. That would be pretty tough, even with a cold MIG. It's no wonder the new tanks are blow-molded poly.
Later,
Vader
"No matter how hard you try you can't stop us now..."
Adobe Acrobat Reader 4.0
Later,
Vader
Car: 89 IROC
Engine: Yes
Transmission: That, too.
Yeah, but knowing Jester he'd still try to arc weld the blow-molded poly tank, with more or less similar results.
89 IROC with lots o' stuff
-=ICON Motorsports=-
jester i welded the sump on mine with no major problems why can't you?
ICON Motorsports
1st & 3rd
ICON Motorsports
1st & 3rd
<font face="Verdana, Arial" size="2">Originally posted by D_Amlee:
</font>
</font>
LMAO for my next trick, I WILL try welding blown poly..bet I can do it
JSP Motorsports
ICON Motorsports
DA,
Good one! What kind of filler would you recommend, polyethylene or GRP?
(Actually, I've had fair success with "welding" poly and PVC with the electric heated air torches, so we shouldn't pick on him too much - pick on him just enough.)
Ede,
Not everyone is the "Master of Molten Metal" as you are. If I had a tough weld job, you'd be hearing a knock on your door... At least I can succesfully stick a rod to almost any metallic surface. Cutting off the excess has always been the tough part. I've made plenty of "coat hooks".
Jester,
A small MIG isn't THAT expensive, and can be indispensible around the shop. You can catch the used portables on eBay for under $150.00. They're usually adequate for most steels up to 3/16" and can be pushed to penetrate adequately on clean 1/4" steel if necessary. Most everything on the car/truck is lighter than that, like LCAs, floors, body panels, and fuel tanks. the gasless ones can cause a little spatter mess, but no worse than the electrodes you are now using.
Later,
Vader
Ede,
Jester,
Later,
Vader
i know jester would never admit to it, but he couldn't of done it with out me coaching him thru it. that's my boy
vader while jester was welding his gas tank i cut up 2 sets of valve covers and made my tall set. used a torch on one a nd mig on the other, both with about equall results. my eyes are starting to let me down a little and bi focals make it a lot harder to see everything. i think tig would of been the best way, but i didn't want to clean them up and my tig doesn't have a foot pedal.
ICON Motorsports
1st & 3rd
ICON Motorsports
1st & 3rd
Ive found the best way to weld a gas tank is to have a cold case of beer. fill up the tank with gas and smoke a cigarette. Once you start to tack it(doesnt matter if its mig, arc, or tig) your problems are all over..
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You know, last night I was going to suggest that filling it with gas would keep the metal cooler and prevent burn-thru, but I thought that would be in poor taste.
I would probably prefer a MIG welder, but am surprised no one suggested an acetylene torch to braze it.
It could very well see more use than a MIG welder since it is so versitle - welding, brazing, soldering, silver soldering, heating parts for assembly/disassembly and bending, quenching, cutting steel, melting the plastic caps off the stock factory u-joints, soldering/welding aluminum, just to mention a few often used applications.
While sort of off topic, I've even seen it braze aluminum that wets, flows and penetrates like nickel bearing silver solder, melting at 1080°F. For soldering aluminum, it'll melt at 780°F making pretty joints with high quality flowing, just like solder on copper pipes; great for working on aluminum radiators, etc.
Okay okay, so it's a lot off topic, but I just couldn't resist...
Mig are damn cool there is no doubt, but after this I don't think I'll ever bother. I dont care how neat a weld looks..just how well it works. I just did .030" steel with an arc, so I don't think I'll ever really NEED a mig. The few times, if ever, I do I don't think I'll mind paying someone to do it.
JSP Motorsports
ICON Motorsports
JSP Motorsports
ICON Motorsports
ambainb
04-25-2016 09:21 PM
beachrodder
08-25-2015 08:05 AM
AkDrifted
08-17-2015 07:45 PM
