TB bypass re-routing...
Old 02-09-2001 | 11:44 AM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
I was wondering if anybody else has done this. When i did my TB coolant bypass instead of making that sharp bend to run over to the stock diverter valve i ran the hose straight out and made a soft radius at the radiator that then takes the hose down along the framerail, up at the back of the coolant reservoir. I relocated the diverter valve to right behind the pass. side strut tower, and ran the heater supply hose out of the way back to the heater.
So for a few dollars of hose that needed to be replaced anyway, i hae elimiated a piece of junk that was in the way of trying to work on the engine.
Phase 2 will be relocating the AIR diverter valve to the frame by the battery and extending the hoses off it.
TPI ain't so hard to work on if you plan this stuff out...ed
Ed Maher - Moderator @ The Carb Board
92 Z28 Convertible - Quasar blue / Tan top
LB9 4L60 GU2 G80 - stock, soon to be sleeper
- Definitely prototypes, high powered mutants of some kind. Too weird to live, too cool to die
Old 02-09-2001 | 09:50 PM
Macgyver's Avatar
You should write a tech article.
Old 02-09-2001 | 10:13 PM
DSouthern's Avatar
Ed,
This sounds like on interesting mod. A picture of it would be worth a thousand words.
Dave
Old 02-10-2001 | 07:23 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
I did the same thing, plus I cut the nipples off the TB so they are out of site. Check it out. TB Bypass
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey, 22# injectors, Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
[This message has been edited by GMTech (edited February 10, 2001).]
Old 02-10-2001 | 11:38 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
I did the same exact thing! I used plastic pipe holders from Home Depot (For plumbing) and took the nails out and replaced them with self tappers. Loomed the hose up and ran it under the sheet metal brace for the pass side strut tower and hooked it to the vacuum coolant switch thingy right in front of the blower motor with a little bracket made up to hold it firm. I ditched my a/c though and used a blower motor and box from a non a/c. Really looks cleaner, don't even have to alter the heater hoses, just bend them over.
djmarch
05-08-2016 11:32 AM
AmpleUnicorn88
South West Region
12-11-2015 11:53 PM
$750 L98
11-07-2015 02:26 PM
skinny z
Carburetors
09-29-2015 11:25 PM
Formula8r89
09-22-2015 04:24 PM
Quick Reply: TB bypass re-routing...
