cam for my engine
Car: 1999 Z28
Transmission: A4
cam for my engine
Ok, I would like to step up the performance of my camaro. I would like to know what cam would go good with my engine.
I have an LG4, with 190,000 miles. The engine is stock. I have a 700r4 tranny, and 3.23 gears out back. I want to leave the rear at 3.23.
So which cam would be best for my engine? Will it hurt to put a bigger cam with that many miles? I ran a best of 16.5 last summer, pure stock. I am about to add a nice catback from banks.
What do you think my new 1/4 would be with exhaust and a cam that you suggest?
Thank you.
Thank you.
Car: 4
Engine: 6
Transmission: 5
Get an exhaust, all the way from the heads to the street, BUT NOT FOR LG4. Get something chassis-specific, not universal, like SLP or Edelbrock; for something like a 350 TPI, and a direct-fit cat such as a Catco and the cat-back for the same application.
I'd recommend a Comp XE256H, with the valve springs and hardware to go with them tha tComp recommends.
Get a L69 dual-snaorkel air cleaner; NOT an open element.
You should get close to 14s with those things, if not all the way there.
A torque converter would make a MASSIVE improvement also. Something around 2400-2500 RPM. The above mods plus a converter should put you well down into the 14s.
Car: 1999 Z28
Transmission: A4
thanks for the quick reply. I thought maybe with exhaust and that cam i would only hit high 15s. I would be happy with mid 15s even
thanks
thanks
Car: 87 Camaro LS
Engine: LG4
Transmission: T-5 World Class
Axle/Gears: 3.08 Open baby!!
get some headers and an exhaust like he said
I'd get a cam with about 488 lift, that will getyou to about 6,000 rpm
take off the heads and mill them and port them also
your car will be mid 14's then
Car: 4
Engine: 6
Transmission: 5
You should do that yourself. It costs by the hour to get somebody else to do it, and it takes alot of hours, and the people who do it aren't cheap because they will be experienced and know what they're doing.
It's pointless (well, not pointless, but certainly not fully pointful) to port & poish them while leaving the stock small valves in them. If you're going to work them up, get 1.94" intakes cut into them; and use undercut-stem valves, such as Manley Street Flo. If they were mine I'd also get the guides cut for Teflon seals, have the studs converted to screw-in with guide plates, and have the push rod holes enlarged.
Trouble is, by the time you pay somebody to do all that for you and buy all those parts, you'll have as much money tied up in them as you would if you just bought new aftermarket ones; except that instead of brand-new performance aftermarket heads, you'd still have old junk stockers, with a bunch of work done to them. That's especially true if you pay to have somebody port them for you.
So if you aren't going to do the port work yourself, you might want to look into replacing them instead of working them up.
Car: 1999 Z28
Transmission: A4
good info. What would happen if i left the heads alone, and put the cam in, and exhaust on? would it be worth the money?
Car: 4
Engine: 6
Transmission: 5
Either a cam or exhaust by itself won't gain you much; but the 2 together attack both of the strangle points in the LG4. Even without head work they would be a HUGE improvement.
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
Originally posted by Jgolden314
thanks again for the info. How much money am I looking at to have the heads ported and polished?
Car: 1999 Z28
Transmission: A4
well, is this something that isnt that hard to do? I have never messed with heads and i am somewhat nervous to try it myself. If i do it, it wont be for a few months anyway. I am guessing there are parts you do not polish, and there is a certain thickness to take off?
Engine: 305-4v
And, yes, you CAN do this work--it ain't rocket science. The hardest part is actually believing that you can do it. But you certainly can!
Car: 1999 Z28
Transmission: A4
thanks for the reply. You are all great help in motivating me to do it myself. Again, I probably wont be doing it until summer, but I was curious now.
Gotta find the templates now and print em up!
thanks all.
Golden
thanks all.
Golden
84z96L31vortec
08-20-2017 12:16 AM
84z96L31vortec
08-10-2015 08:27 PM
