engine siezed... cam/lifters still good?
Car: 87 camaro
Transmission: 5-speed
my gf decided to perform that castrol commercial experiment where they drain all the oil out of the car and see how long it will run for. it decided to stop yesterday.
i put the engine in the car about 9 months ago, i put a cam in it when i did it. what are the chances the cam + lifters would be okay to put in the new engine? thoughts?
i have a 30k motor from a friend that i can put in. but if the cam is roasty toasty shes just getting the next motor put in as-is cos she wont have enough dough to get another one.
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
pull it out and inspect it, only way to ever really know.. maybe shes lucky?
Car: 71 Skylark
Engine: BBB-430
Transmission: M20
it seems un likely, but they might be. As long as the cam has no vissual problems. i'd mic it tho. The lifters are liable to be full of metal tho,
Car: 87 camaro
SURVEY SAYS....
cam is still good. not a mark on it. the engine lost rod bearings on 1&2, but there were no other signs of damage inside.
too bad the "new" motor is a roller motor. guess i can save this cam and put it in something else. it has about 10k on it, if not less, still looks brand new.
Car: '94 Corvette
Even with the lack of visual defects on the lobs, the cam itself may have twisted or it might have micron cracks from the heat (who knows).
It's not even a thought, it's like reusing a bearing that looks good from the same assembly. Forget it - it's a paper weight and the lifters with it.
Ron
Ron
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
Originally posted by lunatic_magnet
SURVEY SAYS....
SURVEY SAYS....
NinjaNife
08-23-2015 11:49 AM
