Comp XR288HR-112: too much for street/strip?
Car: '89 Formula
Engine: 355
Axle/Gears: 9 bolt
My combo is: 355cid, Ported ProTopline 200cc aluminums, 10.3:1 compression, 1.75in shorties, StealthRam, 1.6 rockers, 3.45 gears, converter (stall to be determined after cam choice). I am willing to deal with a choppy idle, and if the car is driveable on the street, thats good enough for me. I just want decent power brakes. Im planning to get it ground on a 112 LSA as opposed to the 110*, hopefully this will help out the vacuum some. What are you guys opinions? Too much? Will a mail-order custom PROM (pcmforless) be able to take care of the programming for a cam this big? Anyone used this cam?
Car: '92 droptop bird
Engine: 5.7L,mild cam etc.
Transmission: modded 700r4 w/2600
go for it ,the 288 cam is fine especially with the 112 lobe sep,had the 286 110 lobe it was more aggresive than i wanted for my driver it would have stayed in my bird if it had a 112 lobe,you should consider a 3200/3500 stall,just my opinion i am sure many will agree....
Car: '89 Formula
Engine: 355
Axle/Gears: 9 bolt
I was originally going to go with the SLP 2600 stall, but that probably wont be enough for this cam. I will probably end up with something in the 2800-3000 range if I go with the 288. Forgot to mention the specs... 288*/294*, 236*/242* @ 0.050, .555"/.576" lift with 1.6s, 112* LSA
Dont get stuck on only looking at XE cams.
Check out the GM 847 or if you really want the best of all worlds check out the Crane solid street roller grinds.
We are in the process of slapping together a Crane solid roller HSR 383, 236/244 @.050
Car: '89 Formula
Engine: 355
Axle/Gears: 9 bolt
I was looking at the XE cams because I heard that they can provide better vacuum due to their aggressive ramp rates. Not sure if theres any truth to this, however.
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
How many miles per year you plan to drive the car?
Once you take a hydra roller up past 230 or 236 @.050 vaccum and idle will really start to take a hit, in the XE series.
A solid roller will give a much better idle, a much fatter TQ curve, work better with big heads as it will get to max lift faster, and will not float the vlaves.
This Crane we are plugging into the 383 HSR will be our first solid roller motor, however it wont be the last as I never plan to run a hydra roller cam again in a weekend/cruiser car.
Car: '89 Formula
Engine: 355
Axle/Gears: 9 bolt
solid rollers have more agressive ramp rates then hyd lifters will ever have.
Omnious, the car is a sunny weekend only type, not a daily driver. I was under the impression that a solid roller will clatter enough to give a knock sensor false signals. Or is it a different type of vibration that the sensor can differentiate? Too bad I just bought a set of Comp R hydraulic lifters, hard to justify buying a set of solids and letting a $200 set of lifters sit on the workbench. Do you think that vacuum would be bad enough that reserve canister would be a must with 288HR?
I would think long and hard about the valvetrain in a weekend pleasure cruiser.
I took the XE plunge and its cool, however once I get some cash in my pocket I am going solid roller. I dont like the idle of the hydra roller all that much, 224/230 cam.
The bottom line is that in the size range you want to run, a solid roller looks real atractive: better idle, fatter curve, no valve float, good chance of getting through emissions.
You could always sell the R lifters.
Car: 91 Camaro Vert
Originally posted by OMINOUS_87
It would need to be disabled via the chip.
Pac J
05-17-2020 10:44 AM
no green
01-09-2016 09:22 PM
