Any opinions on Motorvac cleaning system?
Car: 87 Firebird (Hasselhoff special)
Engine: 2.8L of PURE STOCK POWER
Anyone ever had their car injectors cleaned using this motorvac thing? The mechanic said it works wonders to restore injectors. My car has 230,000km and I figure it wouldn't hurt to clean 'em out a bit. Only thing is, mechanic quoted about $160 bucks to do it.
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1996 Jeep Cherokee
Engine: 4.0
Transmission: 5 speed
I have used the motorvac at my school and it does work really well. You would definitly be able to tell a difference in the way the car runs afterwards.
I had it done at 18,200 miles on my T/A. It still didn't run right. One season, a bunch of frustration, and about 2,000 miles later I pulled the injectors and sent them to Cruisin' Pergrmance.
I must have had a bad experience with the MotorVac process, since the only thing it apparently cleaned was my wallet. Rich got my injectors cleaned, spraying correctly, and flow-matched. With gaskets and other parts, it was still cheaper (but more labor intensive) to remove and clean them.
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
http://www.amsoil.com/products/api.html
One ounce per 10-gals gas at every fill-up. Adds about $.04/gal, keeps them clean constantly.
You'll have to go through 4000 gals of gas to spend the $160.
someone972
08-30-2015 12:52 AM
Street Lethal
08-13-2015 08:28 PM
db057
08-11-2015 10:11 PM
