Casting Number
Car: 1990 RS
Transmission: TH-350
Casting Number
i have a block with a 10066036 casting number and it pulls up as a target/goodwrench crate motor block made in mexico, 2 peice seal. it doesnt say what year or anything and i was just wondering if this is just a basic pre-86 block. are these blocks any good? thanks in advance.
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
ive heard of the mexico engines haveing cracking problems if you do a search its been said on here before but i dont think that all of them are bad personally .....ive had one before and never had a problem out of it at all except for a bad ring and that wasnt the blocks fault it was the yahoo that i bought it from
Car: 1987 Trans Am
Engine: tree-fiddy
Originally posted by thegeneral
ive heard of the mexico engines haveing cracking problems if you do a search its been said on here before but i dont think that all of them are bad personally .....ive had one before and never had a problem out of it at all except for a bad ring and that wasnt the blocks fault it was the gringo that i bought it from
HUH?
1 Post
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
That is the "hencho en Mexico" crate engine. I believe that the "hencho en Mexico" part picked up after the Targetr line stopped production, although i am not certain about that. It is the type of engines that are designed for trucks. Crappy heads, crappy cam, about 250 hp, roughly low to mid 8's for compression as they are assembled with, i beleive, 76cc heads. Its the type of engine that oh, say, you get under a warranty replacement or possibly a fleet engine. Absolulty not a performance minded engine in any aspect. The block itself, i have HEARD that it is cast with a softer or lesser quality iron making it a weaker block, though i have no proof of that and cannot back up the validity of that statement. Just be careful.
Oh yes, almost forgot, it is a flat tappet camshaft style, as ede suggested.
As for the Doctor editing the Generals post, he changed "yahoo" to "gringo." In light of the fact that the block was "hencho en Mexico."
1 Post
Car: Z28
Engine: Sb2.2 406
(of course my wife says that im never all there)...lol
I blame it on the over-exposure to carb cleaner (my gf says the same about me )
Car: 1985 Chevy Camaro IROC-Z
Engine: 350ci from 79camaro
Transmission: 5 speed manual on lsd
you should be able to read of the age of the block as there is a date stamp on those blocks. It is on the side between cylinders 5 and 7 I think. Should be able to get you the month too. not sure of how to decode the numbers, so do a search on the internet for casting number decode etc, and you should find out how.
Si.
Si.
LT1Formula
10-08-2015 08:34 PM
3.8TransAM
09-27-2015 08:37 PM
