Horsepower obtained with stock in tank fuel pump and lines...Who has the most?
Just wondering how much HP guys with stock fuel systems are making? Either TBI or TPI. I am running a TBI pump and lines with my 406....never seems to run too short on fuel....haven't had time to work the bugs out to be for sure.
Originally posted by dankhound
The stock system, both tbi and tpi, is good for around 600hp.
At carb fuel pressure levels they are adequate for mild engines. Raise the pressure and they won't be able to keep up.
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
More pissing in-the-wind contests.
The TBI pump is the same as the TPI pump. The only thing that changes is the pressure, which is done by the FP regulator.
Go to any parts place online and look. The replacement numbers are all the same for both engines.
Sorry thats not true. I don't care what aftermarket replacement pumps are listed. The stock pumps are different.
GM lists the 25168719 EP386 for TBI and 25116163 EP241 for TPI.
If what you say is true than none of the TBI folks would have trouble with maintaining 20psi or more.
Try and dead head a stock TBI pump. It won't produce near the pressure a TPI pump will.
EP386...... that's the AC Delco that three different places I've seen list for the TPI. Why would they do that if it didn't work with TPI?
I won't argue because I am not 100% either way. But I didn't think they were the same pump. I didn't even believe the stock TBI setup has a FP regulator. If it does then it had to be in the TBI unit itself. Not only that, but if you ever turn a TBI pump on not hooked up to anything, there is no 45 pounds of pressure coming out of it. I will have to look at those part numbers. The only way i can see it making 45 pounds is just by constricting the flow. But I don't know if you could do that and still meet fuel demands. Interesting topic.
I also didn't know about 600hp, but I think its possible. Mine is feeding probably close to 500hp. Of course that is not dyno proven power, only what I would estimate.
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
I`ve gone 11.20`s @ 120 with the race wieght at 3850....you need at least 550 at the back tires to do that...so my stock tpi pump, mind you it came with the car in 1985, is feeding the carb just fine apparently
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
TBI and TPI pumps are not the same. Period. TBI pumps support 9 to 12 psi and TPI pumps push 40+. They are however interchangable. That is why you may see the same part numbers for them. However, you cannot use a TBI pump with TPI but you can use a TPI pump with TBI. TBI pumps can support gobs of power on carb set-ups (low PSI) but can barely supply enough pressure on a 200hp TBI set-up (medium pressure). TPI injectors won't even work with a TBI pump. If you have a modded TBI set-up the fuel pump is one of the first things to be changed or you will never meet the pressure demands at high rpm's and engine load.
So cliff notes.
TBI pumps are not the same as TPI pumps
TBI pumps can support high HP carb set-ups
TBI pumps cannot support high HP TBI set-ups
TPI pumps can be used with TBI set-ups and are needed (or equvalent pump, ie Walbro/Holley) with heads and cammed set-ups.
A TBI regulator will keep the pressure right where it needs to be and send the rest down that amazing thing called a return line when multi port fuel pumps are used.
So cliff notes.
1 Post
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
So cliff notes.
So cliff notes.
Car: Transam
Engine: ZZ4,Holley Stealth Ram,Commander 950
Ive got a proven 422 bhp with Holley Stealth Ram and my standard TPI pump doesnt seem to have a problem.I do have a new Walbro one though,ready to fit should there be a problem
cheers
PM
cheers
PM
theshackle
03-05-2017 06:37 PM
beachrodder
08-25-2015 08:05 AM
AkDrifted
08-17-2015 07:45 PM
