Primary vs Secondary ignition
Old 02-10-2004 | 03:46 PM
lucas's Avatar
The car had some problems a week ago and after trying to figure out what was up with it I decided to limp it over to the shop. The shop took care of the hard cranking problem (bad conductivity on the negative battery cable). But the car still surges badly and dies randomly making it undrivable.
The car will run fine when it is cold but after it warms up a little it will start to miss very badly. When I attempt to drive it like that it will surge up and down 1000 rpm at a time and if a lot of gas is given it will backfire. The car will basically not go over 10 mph in the shape.
The shop could not tell completely what it was because the problem is so intermittent and comes and goes. They did say however the secondary ignition fails when the problem shows up, but they can not rule out the primary ignition. They wanted 600 bucks to replace the ignition coil, ignition module, and pickup coil. Since they couldn't confirm what the exact problem with at least some certainty I had it towed home.
I am going to replace the secondary ignition components myself, but what parts of the system make up the primary ignition components?
Old 02-10-2004 | 03:54 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Primary side = the parts that work at 12V
Secondary side = the parts that work at high voltage; i.e. handle sparks
Primary = module, pickup coil, coil
Secondary = coil (has 2 windings, turns 12V pulses in the primary winding into 30 kV pulses in the secondary winding), coil wire, cap, rotor, plug wires, plugs
Sounds to me like a good place to start would be a cap and rotor.
Old 02-10-2004 | 03:55 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
Primary is the low voltage side(most of the stuff the shop recommended replacing). Secondary is the high voltage side(half the coil,wires,plugs).
Old 02-12-2004 | 12:10 PM
lucas's Avatar
Turned out to be the ignition coil.
Old 02-12-2004 | 01:12 PM
Meatikis's Avatar
Car: '86 Z-28
Engine: 350 bored .030 over
i've had sort of a similar problem. what would cause the ignition coil to fail every 6-9 months?
Old 02-16-2004 | 09:01 PM
lucas's Avatar
Interesting question, one that I would like to know the answer to also. My car ran fine for a week with the new coil and now is doing the exact same thing it was before. I have a feeling the coil failed again.
What could cause a new coil to fail?
Old 02-17-2004 | 07:27 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Usually, too much plug gap....
Anything over .045" greatly stresses everything in the secondary part of the ignition; but especially the coil, which has the thinnest insulation of any of it.
Old 02-17-2004 | 07:38 AM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
$600.00 Never go back there again..
Hotrodboba400
12-10-2019 08:07 PM
RedLeader289
05-28-2019 02:47 PM
Gunner242
12-25-2015 05:49 PM
thunder57
11-07-2015 03:28 PM
Justins86bird
09-27-2015 10:43 AM
