Hatch Release...
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
Hatch Release...
I recently purchused a hatch release on ebay due to the pull down motor that i currently have being fried out..
here is a pic of it.. http://cgi.ebay.com/ebaymotors/ws/eB...ayphotohosting
I'm assuming I misjudged by the picture and thought that i would be able to solve my problem with this.. to the best of my understanding its not a hatch pull down motor but a hatch release where you would just manually close the hatch and be able to pop it open through use of a toggle switch set up inside... am i correct in this assumption? If you look at the picture it clearly shows the latching mechanism, however i was mearly sent the motor.. is there anyway to make this work with my broken pull down assembly or do i need to find the correct latch now?
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
thats a hatch release... yea, it makes it so you can open with the touch of a button instead of using the key
it wont help a broken pull down motor.sorry
Car: 1989 Iroc-Z
Engine: 5.7L TPI
When you pull the hatch down on your car, the motor is activated to slowly bring the hatch down and lock it in place. When you hit the latch release on the console, the latch opens and tension from the gas struts will cause the hatch to pop up and rise to the fully (depending on condition of struts) open position.
The Trickster!!!!!!!!!!
yeah i understand its not a pull down motor... i was assuming it was from an older model before they came with them.. in the picture there it shows the actual latch with it so i was going to replace my pull down motor/latch assembly with that one... unfortnently for some reason he just sent me the motor and not the latch that was with it...
formula00ra
Interior Parts Wanted
09-28-2015 11:50 AM
1Aauto
Sponsored Vendors
09-23-2015 01:09 PM
1Aauto
Sponsored Vendors
09-23-2015 01:00 PM
