Numbers for my combo??
Car: 89 Formula
Engine: Carbed 5.7
Transmission: TKO-600
Hey Guys I was just wondering what everyone thinks my car should probably run with what I have in my sig. I was just curious so lets hear everyones input. Thanks guys
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
I'm really not digging the 750 Edelbrock. You'd probably go A LOT faster with a mechanical Holley. With that combo you should be able to hit mid 12's or faster depending on weight, traction, driving skill.
Car: '92 droptop bird
Engine: 5.7L,mild cam etc.
Transmission: modded 700r4 w/2600
man you took the words out of my mouth,that carb is cool to cruise town with but a combo like that needs some holley action in its life,take a look at 88irocs set up he has the most complementing set up....................proven power!!!!!!!!!
1 Post
Car: 1991 Camaro Z28 5.7 G92
Engine: L98 Tuned Port Injection
Transmission: TH700R4
Axle/Gears: 3.23 Posi G80
Yes the 750 it too big and weak. I'd go with a 650 double pumper!! and yes I know I still have an edelbrock too but I can run 13.0 corrected with it and having 2.5 inch exhaust.I am getting my 3 inch catback this week so I expect to be into the 12's.
Car: 89 Formula
Engine: Carbed 5.7
You guys really think a 650 double pumper would be big enough?? IF i was to buy a Demon witch one would you guys suggest??
Car: '89 IROC-Z
750 ....Sure a 650 will work fine with your current combo BUT the 750 will give you room to grow and won't hurt a bit.
Car: '89 IROC-Z
Originally posted by zippy
13.4 to 13.6.
13.4 to 13.6.
The 750 Edelbrock is not holding you back. it is neither weak nor too big. Ya just have to bolt it to a real motor.
It will run just as good or better than a holley.
Start with stock jetting .073x.047 rod .113 primary jet
.107 sec jet. The optimum jetting for your car will be real close to this.
Car: 2006 Silverado 1500
Engine: 5.3L
Thats insane... you are seriously underestimating vortec headed motors
LT1Formula
10-08-2015 08:34 PM
3.8TransAM
09-27-2015 08:37 PM
